20 Most Recent Stanley SL18128P Wearable WetDry Vacuum Questions & Answers
0answers
I have a Stanley 4.0 peak HP wet/dry vacuum
Usually with this type of vacuum the the top motor part unclips then tip the base unit over into an outside drain.
1/2/2011 7:04:30 PM • Stanley SL18128P... • Answered on Jan 02, 2011
2answers
Stanley 2.8 hp shop vac quit working in middle of vacuuming. Emptied tank & cleaned filter. Won't come on.
Try to find a reset button on motor unit. Good luck!!
1/11/2020 12:24:29 AM • Stanley Vacuums • Answered on Jan 11, 2020
I have a 4hp stanley
Locate the three tabs on the float cage where it snaps to the top/motor. Use a flat head screw-driver to gentle pry back each tab and pull the float cage off. In the middle under the motor, is a round hole about 1 inch diameter. Inside it is a fiber filter. with the screw driver gently pull out the fiber filter. It\'s about an inch diameter. Wash it well, and replace it over the impeller and now that baby will suck.
12/15/2012 4:21:23 AM • Stanley Vacuums • Answered on Dec 15, 2012
2answers
Model E130J how do I shut off the led service life on my Aerus CentraLux central vacuum? I have replaced the motor and light stays on. The blue box on the circuit board had the switch ON and MEDI.
To turn off the LED service light on your Aerus CentraLux central vacuum model E130J after replacing the motor, switch the blue box on the circuit board from "ON" to "MEDI."
4/6/2024 1:06:59 PM • Vacuums • Answered on Apr 06, 2024
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM • Vacuums • Answered on Mar 31, 2024
Stanley SL18128P Wearable WetDry Vacuum Logo
Popular Tags
6 questions posted
Top Stanley Vacuums Experts
john h
ADMIN Andrew
ADMIN Andrew
Kate Brownell
Kate Brownell
Are you a Stanley Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Stanley Vacuums
  • Stanley Vacuums
Most Popular Question
stanley 4 0 peak hp wet dry vacuum
  • Vacuums
