20 Most Recent
Kalorik VC16107 Bagless Canister Cyclonic Vacuum Questions & Answers
I have Kalorik ICBM ice
If your ice maker is not working properly, you might be wondering the
reason behind the malfunctioning of your ice maker. Several factors
could be involved in case your ice maker is not making any ice at all.
It might be caused due to a defect in the water supply line. It could be
possible that the water valve isn't getting any water. Check the water
line at the back of the freezer for any blockage. Look for the water
shut-off valve placed behind the refrigerator or under the sink and turn
it off.
Next step would be to unscrew the copper line located at the back of the
refrigerator. Now place the copper line in a bucket and turn on the
valve to check if pressurized water comes out. The problem could also be
linked to a defective tap valve. You could have it replaced. Since,
freezer temperature can also be responsible for ice maker
malfunctioning, make sure the freezer is not too warm.
Take care.
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
Kenmore Beltless Vacuum brush will not spin.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
2/3/2024 5:49:33 PM •
Vacuums
Answered
on Feb 03, 2024
