20 Most Recent
NEC NP400 Projector Questions & Answers
MY NP400 displays the top 1/3 of the screen darker
This is a problem with the honeycomb lens that the lamp first shines through. It will slide up,down,left or right depending how the projector is mounted. I've fixed 4 of these by making sure the lens is in the correct position then adding some metal shims around flimsy frame which holds the lens in place. Can be a pain if it is not lined up and you have to redo it until its perfect. Any metal pieces can be used as shims as long as it does not obstruct the lens.
5/30/2017 3:12:13 PM •
NEC NP400...
Answered
on May 30, 2017
How can I hook up my projector to my ps3
If your projector has a HDMI connection or a DVI.
if you have a HDMI plug it straight in and select either HDMI1 or 2 as your input
or if has DVI you will need a DVI to HDMI convertor.
even if you have VGA you should be able to do it but you getting to many wires involved then but heres how any way VGA > VGA to DVI > DVI to HDMI
1/10/2014 8:52:52 AM •
NEC NP400...
Answered
on Jan 10, 2014
Connection computer
if your projector has a HDMI connection or a DVI.
1/10/2014 8:52:22 AM •
NEC NP400...
Answered
on Jan 10, 2014
