20 Most Recent Konica Minolta Bizhub 222 Black and White Copier Questions & Answers
Code m2 error
sir/mam replace the drum and developer and reset the counters Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/4/2018 8:26:14 PM • Konica Minolta... • Answered on Mar 04, 2018
Bizhub 222 fuser code reset
Small reset button on right side
12/11/2017 11:14:59 PM • Konica Minolta... • Answered on Dec 11, 2017
2answers
How do i fix the error code c2557?
in utility you have somthing like "check counter" try to get inside and then stop00stop01
10/18/2016 6:41:29 PM • Konica Minolta... • Answered on Oct 18, 2016
Konica minolta164
replace the drum and developer Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/27/2016 3:45:49 AM • Konica Minolta... • Answered on Jun 27, 2016
Takes several minutes for the bizhub222 to start printing
last time developer and or drum replaced? also what type of print files printing, do simple letters do OK might need more memoery Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
4/29/2016 12:15:34 AM • Konica Minolta... • Answered on Apr 29, 2016
Change pc drum
will require a tech as certain counters are replaced as is the developer and certain procedures are done after the image unit is re assembled. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 11:47:45 PM • Konica Minolta... • Answered on Jan 18, 2016
How to change paper size in toshiba e-studio166
Toshiba studio 166 Specifications try this site Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/18/2016 3:42:49 AM • Konica Minolta... • Answered on Jan 18, 2016
Bizhub not collating when stapling
did you select collate in the print driver, try reloading the driver check the web site Self Help Product Support Konica Minolta Business Solutions Inc Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/14/2016 3:53:16 AM • Konica Minolta... • Answered on Jan 14, 2016
Dear Sir, I have Minolta BizhubPro 950...the problem is dark copies on the paper.....can u give an email address so i can send u the picture problem on my copier machine
check the cleaning blade assy. and also check the charge corona assy. last time a PM was done on the machine? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 9:49:02 PM • Konica Minolta... • Answered on Dec 30, 2015
How do you fix error EAA002
Has to do with your LAN cable a mail serrver Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
12/30/2015 8:57:16 PM • Konica Minolta... • Answered on Dec 30, 2015
do you mean C2257??????????????????????? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/30/2015 9:51:42 PM • Konica Minolta... • Answered on May 30, 2015
Why do i get a error code c1105 on my bizhub c554e and how do i fix it
Sorry your having trouble. Your code suggest you have an optional KM FS-534-535 finisher attached to your copier. The code is triggered by an internal part within the finisher and should be thoroughly inspected only by a certified factory trained service technician. I would suggest you contact your local repair company. Attempting to resolve this issue on your own could produce negative results.
6/5/2014 4:53:46 PM • Konica Minolta... • Answered on Jun 05, 2014
Always go back in and double check the PC life counter after the reset before F8. More than once the PC Life did not reset on the 1st attempt (other counters do reset 1st time) Take a quick look see.
4/11/2014 7:51:21 PM • Konica Minolta... • Answered on Apr 11, 2014
Error code f-26-3
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit if this is a bizhub 222 the toner density error code would be c2557
3/21/2013 2:56:18 AM • Konica Minolta... • Answered on Mar 21, 2013
Transfer seperator corona location
The transfer unit is located indoor the right cover.This model not use transfer corona ,use transferr roller2_14_2013_6_31_16_pm.jpg2_14_2013_6_31_32_pm.jpg
2/14/2013 6:31:45 PM • Konica Minolta... • Answered on Feb 14, 2013
How do you the sensorATDC CLEAR c2557 in c451
No.Instal the new unit and the copier automatically clear the old IU counter.
1/30/2013 7:12:33 PM • Konica Minolta... • Answered on Jan 30, 2013
Konica Minolta Bizhub 222 Black and White Copier Logo
61 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
transfer seperator corona location
  • Office Equipment & Supplies
