20 Most Recent
Toshiba estudio 255 Copier Questions & Answers
Ttrying to print from A4
Have you made sure you changed the drawer size setting on the copier as well as the physical size of the drawer?
F105 reboot call for service
[F105] HDD other errorCheck if the connectors of the HDD are disconnected.Check if the connector pins are disconnected or the wires of harnesses are broken.Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If the check result is failed, replace the HDD.
I am getting this error: Call for Service. How can I fix this?
You should try to get the error code from the machine, and then include it in your post. To get the error code: press [CLEAR] button and [8] button simultaneously, and copy down the results. Post the error code in this thread to assist you with the correct troubleshooting procedure.
