20 Most Recent
Rimage Amigo II (555501201) CD-R Burner Questions & Answers
I get the error "printer not found" - do I need to
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Correction : I get the error "printer not
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Get a message "Label Rendering"
If you are using the supplied CD Designer label design program, it could be that you have the wrong printer label template selected. e.g. the Everest template for your PrismPlus Printer, or vise versa.
- techwaredist
Autoloader
Do you have a system with USB or an older system?
