20 Most Recent
Polk Audio RT1000I Speaker Questions & Answers
Hi, I have a pair of Polk RT1000i powered towers
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Crazy cycling noise
a quick test, change the speaker wires between the speakers, if the sound goes over to the other speaker the problem is in the amp. But if the problem stays with the same speaker tower the problem will be in one of the speakers in the tower. since you said you get no sub sound I suspect ithe problem is not the amp, but the sub speaker itself
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i...
Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound .
Solution to my Protect Mode Problem - Polk Audio Forum
Feb 15, 2010
Speakers causing the Power Amplifier to go into protection ...
May 9, 2016
PA D4000.4 starts up in protect mode? - Polk Audio Forum
Aug 22, 2012
PA880 Help Needed - Protection Light - Polk Audio Forum
Apr 3, 2013
More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting
Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread
Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote...
One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
I have a Polk audio PWS 110 powered subwoofer. Static sound is coming from the speaker. I have checked all the connections and everything appears to be ok.
go to the hardware store and buy a cheap plug-in polarity checked for the electrical socket. If the polarity is reversed, or your ground is improper is will give you a different colored light. Polarity is easy to reverse. Shut off the main breaker box in your home and simply take the cover off the outlet and swap the two wires with the narrow and wider blades on them. Make sure the ground wire is actually grounded to something like a water pipe of connected to the house ground rod, #4 rebar, 18 inches long with a thick copper wire and brass auto batt connector will work fine... bury it deep and remember where it is in the flower bed underneath a window sill outside. If the subwoofer is near the TV, you made be getting interference from it, if the cabinet is not shielded against RF.
