20 Most Recent Magnavox 19MD359B F7 19 in. HDTV Questions & Answers
Magnavox DVD/TV combo won't play DVD
try a cd and see if it plays
2/23/2016 7:24:59 AM • Magnavox... • Answered on Feb 23, 2016
How do I get rid of diagonal lines across my Mag. HDTV screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
11/6/2014 12:26:56 PM • Magnavox... • Answered on Nov 06, 2014
0answers
0answers
Tv master reset
Be the first to answer 9/16/2013 8:17:28 AM • Magnavox... • Posted on Sep 16, 2013Be the first to answer
How to scan for channels
Go to page EN-23 of the link for instructions.http://download.m4c.magnavox.com/files/1/19mf338b_27/19mf338b_27_dfu_aen.pdf
1/29/2013 3:32:31 AM • Magnavox... • Answered on Jan 29, 2013
Tv not powering off and screen colour keep on changing
T--con board just replace it..
6/15/2012 6:59:17 AM • Magnavox... • Answered on Jun 15, 2012
2answers
Magnavox 19 in lcd manual guide
Here is the link to the manual of Magnavox 19MD359B (19 inch LCD TV)
Magnavox 19MD359B
If that is not the model of your TV (there are many models of 19" magnavox TV) please indicate it so I can look it up for you.
You can rate my answer if you appreciate my work for looking for the manual of your TV.
Thanks.
-damneddle
10/6/2011 2:25:39 AM • Magnavox... • Answered on Oct 06, 2011
Bought a magnavox hdtv modle #19md357b137b at an
This is generaly a 4 digit code that one would put i during set up.
most people don't use that option and most of the time (if it hasn't been used) it's 0000.
if that doesn't work, you may have to go back to where you bought it or contact the manufacturer
9/3/2011 8:14:23 PM • Magnavox... • Answered on Sep 03, 2011
You have a bad capacitor in the power supply. If you can remove the back cover, you may see a bulged capacitor or two. Replace these and your TV will come back to life. I'm sorry, I do not have capacitor values and locations at this moment. But, the fix should be fairly simple. If you have some elctronic experience, you can fix this. Thanks for asking and show all hands of support!
8/13/2011 11:06:27 PM • Magnavox... • Answered on Aug 13, 2011
NO POWER ON
Hi ,
Here are some DIY steps that may help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical.
You can also look for availability of power supply at .ebay.com and shopjimmy.com if you want to replace the entire unit.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Give a thumbs up if you find it useful.
Thanks for using fixya.
2/7/2011 2:29:58 AM • Magnavox... • Answered on Feb 07, 2011
What to adjust if text not sharp?
With a Magnavox, you just buy a new television. They are not good quality and that model is only 720P. Old tech. https://www.google.com/search?q=Magnavox+22ME601B%2FF7 ..
2/25/2024 6:25:10 AM • Magnavox... • Answered on Feb 25, 2024
Trying to use my Magnavox 15MF400T/37 as a monitor with a VGA cable, but I am having trouble finding the PC input option. Input options ar AV/TV/S-Video.
it does not have one. You cannot directly connect VGA to composite or svideo since they are two completely different and incompatible signals. However, you can use a converter like PID# 4724 or 4722 to actively convert between these types of signals. google s video to VGA apater
1/9/2024 10:32:05 PM • Magnavox... • Answered on Jan 09, 2024
My Magnavox Smart tv comes on but then sticks on one channel and it won't do anything.
Try pressing the Source button on the Remote and run through all the Input options. You can also try a full Power reset. Disconnect the power to everything for 5 minutes including the router. Plug back in, wait 10 minutes. Switch television on and try again. ..
1/4/2024 7:45:41 PM • Magnavox... • Answered on Jan 04, 2024
Need code for my TV using magnavox nb672 remote
12/13/2023 4:34:27 PM • Magnavox... • Answered on Dec 13, 2023
Magnavox 19MD359B F7 19 in. HDTV Logo
23 questions posted
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Magnavox Televison & Video
Most Popular Question
tv not powering off screen colour keep
  • Televison & Video
