20 Most Recent
Sony NWZE345 MP3 Player Questions & Answers
I have a walkman nwz-e345. Recently the volume has
i have the same exact problem. the volume down button works ok. the volume up button seems to do any of a number of different functions other than turning the volume up again. it has just gotten worse and worse. christ damn i hope someone can figure out a fix.
My sony NWZ-E445 is stuck on home screen
I have the same problem here. Looks like the cause is permanent bad sectors in the flash chip, unfortunately there is no fix because it lacks wear leveling (cheap junk chips). If you can rewrite it at a low level there is a small chance it may recover, maybe try and find the _WP pin and bypass it as this works for unformattable pendrives as well.
How do i reset my mp3 player its just frozen?
How Do I Fix My Sony MP3 Player That Froze & Won't Turn On?
Sony Walkman MP3 players, like most MP3 players, can occasionally freeze up and stop working properly. Fortunately, there are two simple ways of resetting the Walkman system. The first method takes only 10 to 15 seconds to complete and is an effective way to troubleshoot most technical problems you may have with your Walkman. The second method, unfortunately, may take several hours; it requires you to allow the battery to drain completely. Whatever the problem is that's causing your MP3 player to freeze, one or both of these methods should clear it up.
Instructions
Things You'll Need:
* Paperclip
* Walkman MP3 player charger
Reset Button
Straighten the paperclip and set it aside for now.
Locate the reset button on your Sony MP3 player. On most models, it can be found near the volume control mechanism.
Insert the end of the paperclip into the reset button and hold it down for three to five seconds. When the screen flickers, you'll know that the MP3 player's system has been reset.
Remove the paperclip and wait for the system to reboot.
Battery Drain
Turn on your MP3 player.
Let the battery's life deplete. Since the system is frozen and no music is being played, this will take longer than usual.
Check that the battery is completely depleted. Sometimes the screen just goes dark during this process, but the battery is not actually drained. You can check this by pushing buttons or trying to power up the system.
Connect your MP3 player to its charger and plug it in to a power source. Allow the MP3 player to fully recharge.
Power on the MP3 player. The system should be operating normally again.
PC no longer recognizes my
Hi loreo88...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
When I plug my player
Go to My Computer , right click to get properties. go to third tab hardware and then device manager. Go to very last Universal serial bus controllers. Delete them all . and restart your PC or laptop.
This way your windows will install fresh USB drivers automatically.
My windows xp laptop wont
may be you may have to provide with the device driver or if it is installed you may have to reinstall it.
check the device in other PC to check whether it is the problem of the hardware or not
please got o device manager and check whether the status are proper (enable the device if it was disabled)
please check in all ports
check for viruses
check the antivirus solution whether this hardware is blocked or not
thanx
PLZ VOTE
I have 600 songs in memory and when I try to add
probably even if its 16GB sometime files goes error. check if it has enough space left to store songs... or try to save all your songs first then format it and the save your songs again try if all the songs will be stored after you format.
Connecting SONY TA-D505 amplifier LBT-D505
Hi David, do you want to connect the ST-D505 tuner to the TA-D505 amplifier?
You just have to connect an audio cable of two RCA (red and white) from the audio output L and R of the tuner ST-D505 to the input of Tuner in the amplifier TA-D505
Remember to connect the FM antennas and the AM Antenna Loop on the ST-D505 tuner
To listen to it, you have to select Tuner on the TA-D505 and enjoy the favorite radio stations
I hope you have my comments
Greetings Franco Dosil
Hola David, quieres conectar el sintonizador ST-D505 al amplificador TA-D505?
Simplemente tienes que conectar un cable de audio de dos RCA(rojo y blanco) desde la salida de audio L y R del sintonizador ST-D505 a la entrada de Tuner en el amplificador TA-D505
Recuerda conectar las antenas de FM y la Loop Antena de AM en el sintonizador ST-D505
Para poder escucharlo, tienes que seleccionar Tuner en el TA-D505 y disfrutaras de las estaciones de radio preferidas
Espero que te sirvan mis comentarios
Saludos Franco Dosil
https://elektrotanya.com/sony_lbt-d505_d505cd_d505cdm_d505m.pdf/download.html
The display does not work on my Sony CDP-CE375 CD Player.
troubleshoot the issue:
Reset the CD Changer:
Turn off the CD player.
Press the CLEAR button.
Simultaneously, press and hold down the POWER button on the CD player for 60 seconds.
If this doesn't resolve the issue, proceed to the next step.
Check for Error Messages:
If you encounter difficulty playing a disc and receive any of the following error messages, there may be an incorrect setting or a problem with the disc:
NO DISC
DISC ERROR
CD ERROR
TOC ERROR
Refer to the instructions supplied with your CD player to verify model-specific information and troubleshoot the issue.
Internal Component Repair:
If the display issue persists, it might be related to an internal component that requires repair.
My Sony model # MHC-V11 MAKES NO SOUND everything seems to operate but i cant get no sound from it
Troubleshoot this issue. Here are some steps you can follow:
Check Speaker Connections:
Ensure that the rear surround speakers are properly connected to the Audio/Video (A/V) receiver.
If applicable to your model, verify that the A/B speaker selector is set correctly. If the speakers are connected to the A speaker connection, the selector must be set to the A position.
Test Tone Operation:
Perform a test tone operation to check if the speakers are functioning correctly.
Increase the rear speaker volume or adjust the surround speaker settings to the maximum level.
Speaker Size Settings:
Try selecting a different size (small or large) for the rear surround speakers in the menu.
Surround Sound Mode:
Verify that the A/V receiver is set to a surround sound mode.
For Dolby ProLogic surround sound, ensure that the center-channel mode is set to NORMAL or WIDE.
If your source is a DVD or Blu-ray Disc player, check that surround sound is enabled in the player's menu.
The audio being received must be multi-channel.
Different Surround Sound Mode:
Try setting the A/V receiver to a different surround sound mode.
Source Content:
Verify that the source you are playing is encoded in surround sound.
Note that during periods of mainly dialog, most of the sound may come from the center speaker only, with audio coming out of the rear speakers when there is background or ambient noise.
Factory Reset:
Reset the unit back to factory default settings (consult your operating instructions for model-specific steps).
If applicable, follow the steps for calibrating the appropriate settings automatically after connecting the calibration microphone device.
Speaker Wires and Replacement:
Check and replace the speaker wires if necessary.
Consider connecting a different pair of speakers to see if the issue persists.
If you've tried these steps and the problem remains unresolved, I recommend seeking professional service.
My Sony DHC-FLX7D and DHC-FLX5D is not working due to humidity. Is it possible to repair it ?
steps to troubleshoot and potentially repair them:
Troubleshooting Low Sound or No Audio from Rear Surround Sound Speakers:
If you're facing audio problems, especially with the rear surround sound speakers, consider checking the following:
Ensure that all speaker connections are secure and properly plugged in.
Verify that the speaker wires are not damaged or frayed.
Check the speaker settings in the system menu to ensure correct configuration.
Inspect the speaker impedance and compatibility with the system.
If you're using wireless speakers, check their power supply and connectivity.
Refer to the operating instructions manual for specific troubleshooting steps.
Flexible Circuit Board Repairing:
If the issue is related to internal components, you might need professional repair. However, if you're comfortable with electronics, consider these precautions:
Keep the soldering iron temperature around 270°C during repairs.
Avoid touching the soldering iron on the same conductor of the circuit board more than three times.
Be gentle when soldering or unsoldering to prevent damage to the conductor.
Important Notice:
To prevent fire or shock hazard, avoid exposing the unit to rain or moisture.
Do not open the cabinet; refer servicing to qualified personnel.
Avoid installing the appliance in confined spaces like bookcases or built-in cabinets.
