20 Most Recent
Rimage Prism Plus Thermal Label Printer Questions & Answers
Need driver for rimage prism plus 2
There is no Windows 7 or 8 Drivers for the Prism printers unless you have purchased the New Prism III (the printer is Black) Rimage has no intention of ever releasing a newer print driver.
John Norma
Max Optical llc
I have a rimage prism plus why are my disc not clamping in on tray
Usually this is a bad printer pad, or your disc are not flat? Put the disc on a table, push near the edge of the disc and the opposite side should not lift up. In rare occasions the clamp pins will lower into the mounts. They can be raised with a flat screwdriver but be very carefull. If the pins extend above the CDs they will destroy the printhead ($575)
John Norman
Max Optical llc.
www.maxoptical.com
Our Prism Plus is sometimes
Hello peter_vitsek,
This is usually caused by warped media and should give you an error code. Please check to make sure your media is flat and not bending in the middle.
