20 Most Recent Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive Questions & Answers
My Hitachi 250GB external hard
Check the device manager when it is connected and look for indications that something is wrong with the device also check the event viewer log in the system folder for any errors related to the issue and let us know.
12/23/2017 2:43:35 AM • Hitachi... • Answered on Dec 23, 2017
Hitachi external hd 250gb SimpleDrive
The only thing left is the USB cable and the conversion circuitry between it and the drive connector. Listen to the drive. If it clicks a lot it isn't getting enough power from the USB port on the PC anymore. If it's OK, then it's back to the cable or the conversion circuit.
6/27/2017 4:45:43 PM • Hitachi... • Answered on Jun 27, 2017
My Hitatchi 250GB External Harddrive is not working at all when plugged in to any computer I own/use It makes soft beeping sounds for several minutes and then becomes silent The lights are on, showing
take the hard drive to a computer repair shop but from your description , it may be dead if it is a disc type hard drive , then continually moving it around is not good for the delicate workings if it is dead , replace it with a solid state hard drive which has no moving parts and is a lot more robust
5/5/2017 6:24:43 AM • Hitachi... • Answered on May 05, 2017
0answers
2answers
How do I Transfer files to my external drive?
Open file explorer Select files to transfer Select copy or move http://static.highspeedbackbone.net/pdf/Simpletech-Signature-Mini-MN.pdf
5/5/2015 8:48:33 PM • Hitachi... • Answered on May 05, 2015
My Hitachi Simpledrive Mini 250 suddenly quit....when I lookein the device manager it said Code 10, would not start????
Sounds like a disk error and it cant read the start of the drive. If it still detects it you might be able to repair it with a partition recovery or partition repair tool available online.
12/23/2014 4:58:05 AM • Hitachi... • Answered on Dec 23, 2014
USB DEVICE NOT RECOGNISED - MALFUNCTION
Problem may simply be with USB cable used. Try another cable, preferably a known good cable. Problem may be with the socket on the device itself where the USB cable fits in. Try (with known good cable) on a flat surface with the both the device and the cable resting on the surface - i.e cable should not hang down and put weight on the socket. Hope that fixes it. Further advice. Even if problem seems fixed, immediately back up the drive if you can!
12/17/2013 11:50:13 AM • Hitachi... • Answered on Dec 17, 2013
Can't get computer to recognize my hitachi 250 simple drive
If it is new you may have to format it.Go to may computer right click hit format. If it contains your files etc do not do it as it will erase everything.
11/27/2013 4:05:11 PM • Hitachi... • Answered on Nov 27, 2013
The computer won't recognize the simple 250 with just the USB plugs
It doesn't require a power supply You may need to install a mass storage driver. What operating system are you using? Vista? XP? Win7? Win8? 32 bit? 64 bit? Was the drive used on a Mac? Are you on a PC right now with it?
11/27/2013 2:31:51 PM • Hitachi... • Answered on Nov 27, 2013
2answers
When I plug my my Hitachi SDM/205 250GB Simple
Yes, but there are many recovery software that you can download from the internet.... so don't worry, try 4shared.com by searching Recover My Files which is very effective. Please note to format your HDD using Quick Format rather than Full Format.. Good luck..
1/15/2013 9:50:04 AM • Hitachi... • Answered on Jan 15, 2013
2answers
Cant be detected
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.http://www.asoftech.com/adr/
12/24/2012 4:02:13 AM • Hitachi... • Answered on Dec 24, 2012
3answers
I copied and pasted a
I'd recommend that you download asoftech data recovery to recover files from hard drive. you can download the program fromhttp://www.asoftech.com/adr/
11/9/2012 3:06:17 AM • Hitachi... • Answered on Nov 09, 2012
2answers
Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
5/29/2012 6:35:56 AM • Hitachi... • Answered on May 29, 2012
Hitachi SimpleDrive Mini 250GB USB 20 Portable External SDM250RW (Red Wine) 250 GB Hard Drive Logo
76 questions posted
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Computers & Internet
Most Popular Question
usb device not recognised malfunction
  • Computers & Internet
