1 ***** the size of
files you need for taking the backup. Files having graphics, sound and videos
occupy more space than a simple text file.
2 Plan the future
requirements and consider the space needed accordingly.
3 Choose an
external drive of 20 GB or above to store huge data backups.
4 Get an external hard
drive and connecting cables to attach the drive to your computer.
5 Select the data you
want for backup. Organize the data into folders and sub-folders for easy find.
Financial data, digital photos and music can form priority data for backup.
6 Connect the drive
to your computer. Use the drag and drop options for taking the backup.
7 Remove the drive
after properly ejecting by right clicking on the task bar on the desktop.
8 Keep the external
drive away from the place where you have your computer when done. If your
computer gets damaged due to any unforeseen reason, you will have your entire
data safe in the external hard drive. It minimizes the risk of data loss.
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved click start control panel scroll to folder options view place a tick in show hidden files folders and drivesthis may vary depending on your operating system if you need more help with this post a reply
hope this helps
3 questions posted
31 Questions
11 Questions
