20 Most Recent ASUS Eee 1201NPU17BK Netbook Questions & Answers
How to print screen on Eee PC 1201? it doesnt have Print Screen key
Depending on your hardware, you may use the Windows Logo Key + PrtScn button as a shortcut for print screen. If your device does not have the PrtScn button, you may use Fn + Windows logo key + Space Bar to take a screenshot, which can then be printed.
Keyboard shortcut for print screen - Microsoft Support
8/8/2022 5:19:11 PM • ASUS Eee... • Answered on Aug 08, 2022
Computer is slow
You need to to reinstall windows if the startup and shutdown is slow. You might have a virus or infection so you can try downloading and running MalwareBytes.Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
5/28/2012 3:53:25 AM • ASUS Eee... • Answered on May 28, 2012
1015 PEG Asus Seashell..AC adaptor power cord
You should send it back and explain the problem to the people that sent it
4/10/2012 4:59:46 AM • ASUS Eee... • Answered on Apr 10, 2012
How do i reset my laptop
If it is Vista or Windows 7EASY In CONTROL PANEL select RECOVERY Then "Advanced Recovery Settings" Then "Return your computer to factory settings". Be AWARE you may loose all of your files and after market downloads. Back-UP first!!
1/16/2012 2:25:36 AM • ASUS Eee... • Answered on Jan 16, 2012
If I upgrade from 2 gig to 4 gig RAM for my ASUS
Any 32-Bit Operating System can use at the max of 3 to 3.2 GB of RAM. Hence, when running a 32-Bit Operating System in a computer, then it's advisable to have only 3 GB RAM installed.
6/23/2010 1:58:03 AM • ASUS Eee... • Answered on Jun 23, 2010
2answers
Wd 11 error code:0xc0000034
The last line of your error message contains the solution: "You'll need to use the recovery tools on your installation media. If you don't have any installation media (like a disk or USB device), contact your system administrator or PC manufacturer." Translation: Start up from the disk that came with your laptop and follow repair tool instructions (or contact the manufacturer to obtain a copy - which you may possibly need to purchase. If you are not under warranty this will possibly be at a reduced cost.) Look for a label on the bottom of your pc for a phone number for service if your equipment is not useable. Good luck!
7/21/2022 8:42:08 AM • ASUS Eee... • Answered on Jul 21, 2022
Keys all mixed up keyboard
check using the onscreen keyboard or you can also check with an external keyboard to see if the same issue occurs with those. if it does the issue could be a software related. you can go to device manager, under keyboards uninstall the Keyboard Device and restart the computer.
10/7/2019 8:44:22 AM • ASUS Eee... • Answered on Oct 07, 2019
2answers
I recently purchased an Asus
Hello Machatsiduba, It's likely that the network card is capturing some radio signals phones close to your geographical location. Specifically, the Wi-Fi controller can cause this problem; I recommend you follow these links to solve this problem. 1) https://support.microsoft.com/en-us/help/4000460/windows-10-check-wi-fi-drivers-settings 2) https://support.microsoft.com/en-us/help/4000461/windows-10-wifi-problems-home-layout
5/25/2019 12:13:46 AM • ASUS Eee... • Answered on May 25, 2019
Rog 750 g750jw serial location
x2. the ASUS box has a white sticker on the new box. clearly showing this fact. the motherboard, has sticker to ,for the same thing, same answer, in the BIOS info screens, the serial will bet there and a UUID, serial, that Microsoft uses, to block activation. there a mAC too. you did not say why you need this, so lacking context we guess. omg a gaming laptop... ASUS Rog 750 g750jw on laptops in general, its on the bottom of the case on some remove the battery pack and its a sticker inside there. on newer laptops, the deleted stickers (deemed ugly) so is deep hidden. BIOS pages are it. i look at your mobo, and see only stickers on the ram slots so open the ram hatch and look? I SEE ONLY THIS. i redacted it a bit, to make it neutered. PN: not this. PT? i guess not. lower right, side is my guess, on SN. 69N-bla bla sn-rog-lf2mtn200wr504vgnybkj5cw-1-0.jpg
11/5/2018 1:26:46 PM • ASUS Eee... • Answered on Nov 05, 2018
Call Asus support, or info could be in the manual
11/25/2017 7:53:51 PM • ASUS Eee... • Answered on Nov 25, 2017
My Asus Eee netbook keyboard will suddenly for no
see if you can find out why at this link... Asus Eee netbook freeze up Google Search
10/21/2017 1:03:24 PM • ASUS Eee... • Answered on Oct 21, 2017
I was running avast anti-virus while browsing using chrome when I tripped on the power cable and the system shut down. the next time I turned the power on, I got DISK READ ERROR OCCURRED PRESS CTRL+AL
Hello, Weird problem... situation may have nothing to do with what happened. Your hard drive may have core problems. I would run the BIOS diagnostics if able. Also, boot from the OS install DVD and get to a command prompt where you can run CHKDSK. Good Luck, Steve I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
9/30/2017 3:58:53 PM • ASUS Eee... • Answered on Sep 30, 2017
0answers
Asus keyboard typing * instead of p
one or more keys may be stuck
10/25/2016 1:28:01 PM • ASUS Eee... • Answered on Oct 25, 2016
Can't enable wi-fi on Asus x43u laptop
Usually the wireless problem comes with asus laptop when you do not update the wireless driver properly. so you need to go ahead and updated the wireless driver and then you need to reboot your computer. finally your computer will start working fine. for more information you can visit : Tech Support For Asus
9/19/2016 8:29:50 PM • ASUS Eee... • Answered on Sep 19, 2016
Lost net work adapter and Internet connection
get model number and operating system and download network adapter and Wi fi adapter drivers .Then install on p.c. https://www.asus.com/support/Download/45/7/0/1/POi1J7z06m5LfgvC/41/
9/2/2016 10:35:49 PM • ASUS Eee... • Answered on Sep 02, 2016
ASUS Eee 1201NPU17BK Netbook Logo
11 questions posted
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Eee ASUS
  • Eee ASUS
Most Popular Question
print screen eee pc 1201 doesnt print
  • Computers & Internet
