20 Most Recent
eMachines ET183103 (PTNB602002) PC Desktop Questions & Answers
Cant get any sound on my emachine ET1831-03
Go Into Device manager and check to see if you audio device is Enabled, working properly and the drivers are installed, also check you audio volume.Control Panel\All Control Panel Items\System then on the left click on device Manager.
11/2/2013 12:45:42 PM •
eMachines...
Answered
on Nov 02, 2013
I have just bought an
uninstall your tplink driver, re-start computer and re-install it again.
just an opinion hope it helps.
9/9/2011 1:15:38 AM •
eMachines...
Answered
on Sep 09, 2011
I have a black screen with specs on it that says
If you have Lenove Desktop then there must be 100% sure the Hard Disk with Western Digital make and has gone faulty. No option left but replacing the HDD. You can contact with Lenovo support for the same issue if it's under warranty.
Please rate and vote me if you got my suggestion helpful and informative.
4/21/2011 8:28:36 PM •
eMachines...
Answered
on Apr 21, 2011
Windows error at startup.what can
The best way is to put a Windows CD/DVD in and boot from that.
It depends on what operating system you have to go from there.
If you have Windows XP, follow this:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
If you have Windows Vista or 7, you should be asked if you wish to repair the Windows O/S. Say "yes"
4/3/2011 5:09:30 PM •
eMachines...
Answered
on Apr 03, 2011
Drive won't open
The Drive is usually shot at that point, You can use a Paperclip on the Small hole on the face of the unit to get any Cds out, Or make sure the Power cords are plugged firmly in the back, But your Best bet is to replace it
2/22/2010 12:22:14 AM •
eMachines...
Answered
on Feb 22, 2010
I have restord my emachines computer to factory settings and now it running slow what can i do to speed it up again
add more ram is the best way of speeding up a computer
you might have to many programs running at the same time putting to much strain on the CPU
try uninstalling a few unnecessary programs
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might further damage your computer
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over if you see
something running that you dont need running select end now then you might uninstall that particular program you might have virus slowing your computer you might need to update your graphics card drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrative tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers
if you dont have a disk with the drivers you have to download them
this should speed up your computer
hope this helps you
And i want to enlarge it
Click Start/Control Panel/Display when the display window opens click
the Appearance tab. Look down near the bottom of the window and Change
the Font Size.
I counted 13 quick beeps at startup on an emachines E520. what dose that mean ? how do i fix it please ?
Thirteen quick beeps at startup on an eMachines E520 usually indicate a problem with the laptop's RAM (Random Access Memory). This could mean that the RAM is not properly seated in its slot, or it could be a sign of a faulty RAM module.
Here are some troubleshooting steps you can try to resolve this issue:
Turn off the laptop and disconnect it from the power source.
Remove the battery from the laptop.
Locate the RAM compartment on the bottom of the laptop.
Check to make sure that the RAM module is seated properly in its slot. You may need to remove and reinsert the RAM module to ensure a proper connection.
Replace the battery and turn on the laptop.
If the problem persists, try removing the RAM module and testing it in a different laptop or using a different RAM module in the eMachines E520 to determine if the problem is with the RAM module itself or with the laptop's RAM slot.
If none of these steps solve the problem, it may be necessary to contact a computer technician for further assistance..
3/22/2023 9:07:20 PM •
eMachines...
Answered
on Mar 22, 2023
How to factory reset a Emachines Etower 633id it boots up but says operating system not found it has Microsoft Windows ME Millennium Edititon (from Windows 2000 Professional)
- Boot the computer to the boot menu: To do this, restart the computer and press the appropriate key when prompted to enter the boot menu. On most eMachines computers, this is the "F12" key.
- Select the CD/DVD drive as the boot device: Use the arrow keys to select the CD/DVD drive and press the "Enter" key to boot from it.
- Insert the Windows ME boot disk: Insert the boot disk into the CD/DVD drive and restart the computer.
- Choose the "Start Computer with CD-ROM support" option: When prompted, choose the "Start Computer with CD-ROM support" option.
- Run the Windows ME setup program: The setup program should start automatically. Follow the on-screen instructions to install Windows ME.
- Format the hard drive: During the setup process, you will be prompted to format the hard drive. Choose the "Full" format option to erase all existing data and perform a complete factory reset.
- Install Windows ME: Continue to follow the on-screen instructions to complete the installation of Windows ME.
After the installation is complete, the computer should be in a factory reset state and you can begin setting it up as a new system.
Please note that resetting your computer to the factory settings will erase all personal data and installed programs, so be sure to back up any important data before proceeding with the reset.
2/13/2023 2:51:11 AM •
eMachines...
Answered
on Feb 13, 2023
My local disk E is missing.
device manager
1 of 10000 model ODD optical disk drives made,
each drive made has LIMITS some only do CD ROMS
BD is blue ray , FIY
if missing or maked with red or yellow errors or shows up as unknown that all means DRIVER IS BAD , wrong or missiong
NO PC Told so can not tell you how to fix that, lacking such a key fact . (but is at your oem makers PC support page under DRIVERS)
6/21/2022 8:52:19 PM •
eMachines...
Answered
on Jun 21, 2022
Hi! I have an emachines laptop E525.I is not going on
moved you out of monitors and into laptops, only forum. emachines
full model not old like this example
E525-901G1Mi
windows 7 loaded day1.
- the switch is bad Lid close switch
- set wrong in power settings.
- or the driver is missing that makes this switch work.
so why not just assign the sleep mode, to auto sleep
then on what does the power button do in settings, set to
do nothing or set button to only sleep . (3 choices here)
or
let auto sleep do the work, set. set to say 5min idle.
the switch is inside it deep and if you rip it out as you go there most noobs break 2 or 3 FFC cable jacks and now it is bricked and $300 mobo wrecked
emachines or junk grade, made by Acer.com owned now
and that maker does NOT have service manuals making service a royal Pain.
best is work around the problem as I just told how.
or ask any shop to fix it.
they do know how.!!!
5/16/2022 1:18:24 PM •
eMachines...
Answered
on May 16, 2022
