20 Most Recent Polk Audio PSW50 Subwoofer Questions & Answers
2answers
No sound comes out of the subwoofer. Sound passes
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
9/3/2015 2:12:44 PM • Polk Audio PSW50... • Answered on Sep 03, 2015
0answers
0answers
I need an instructional manual
At this link you can see and download the user manual for your Polk Audio Sub-woofer. In case you need further details for installation or in case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
3/1/2012 1:29:44 AM • Polk Audio PSW50... • Answered on Mar 01, 2012
0answers
Schematic
Be the first to answer 12/6/2011 9:13:11 PM • Polk Audio PSW50... • Posted on Dec 06, 2011Be the first to answer
Have a polk psw50 with
You might get luckier than me at tapping it with a hammer. I ended up ordering a replacement from Parts Express. 8 inch, 4 ohm subwoofer, pick something in your price range, but don't go crazy. Many of the current subwoofers have dual 8 ohm coils. If you get one, connect the coils in parallel.
7/28/2011 7:36:38 AM • Polk Audio PSW50... • Answered on Jul 28, 2011
Have a blown vintage polk
It measures in at just under 4 ohms, so assume a 4 ohm speaker. You can replace this with any number of similar subs, using perennial DIY favorite PartsExpress, there are two under $30 that would meet your needs (Dayton SD215-88 and Goldwood GW408). Looks like they both have dual 8 ohm coils, so you would simply wire them in parallel for your application.
7/28/2011 7:19:46 AM • Polk Audio PSW50... • Answered on Jul 28, 2011
Can replace my polk audio fuse with a T3.15A 250v fuse
It depends on what it is on, but I am seeing mention of a 1 POINT 6 (1.6) amp fuse so NO to a 15 amp fuse. Fuses are there to protect against shorts or overloads. The fix is not to put in a fuse that is 10 times bigger, or you burn out components or wiring. Fix the reason the fuse blew, normally take to an audio electronics engineer. fuse (1.6A) 120vac https://www.google.com/search?q=polk+audio+fuse ..
7/9/2023 10:59:14 PM • Polk Audio Audio... • Answered on Jul 09, 2023
Polk audio pa660 is in protection mode how do I reset it.
Lots of help in the links
Amp goes into protection mode - Polk Audio Forum
https://forum.polkaudio.com > discussion > amp-goes-i... Nov 26, 2018 - As the title says , my 4 channel amp goes into protection mode when I turn my volume up to about 18-20 , causing a loss of sound . Solution to my Protect Mode Problem - Polk Audio Forum Feb 15, 2010 Speakers causing the Power Amplifier to go into protection ... May 9, 2016 PA D4000.4 starts up in protect mode? - Polk Audio Forum Aug 22, 2012 PA880 Help Needed - Protection Light - Polk Audio Forum Apr 3, 2013 More results from forum.polkaudio.com
Protection Light ' Polk Audio PA660.4 Support - HelpOwl.com
https://www.helpowl.com > PA6604 > Troubleshooting Jul 31, 2017 - Polk Audio PA660.4 - How do I turn off or get out of protection so I ca.
Car amplifier(Polk Audio PA660) question - Badcaps Forums
https://www.badcaps.net > forum > showthread Dec 19, 2013 - The amp, is a Polk Audio PA660. It was entering in protection mode. I have found a pair of final transistors shorted at one of the ...
Amplifier Protection Mode Troubleshooting - Car Audio Help
http://www.caraudiohelp.com > newsletter > amp_prote... One of the more confusing car stereo problems can be when an amplifier goes into protection mode. One minute it's working and the next minute it's not, ...
1/27/2022 1:02:36 AM • Polk Audio Audio... • Answered on Jan 27, 2022
3answers
My polk subwoofer makes a heartbeat sound and is
Power off the sub. Push the reset then power back on.
11/1/2019 1:14:21 PM • Polk Audio Audio... • Answered on Nov 01, 2019
Polk Audio PSW50 Subwoofer Logo
15 questions posted
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
k24674
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Polk Audio Audio Players & Recorders
Most Popular Question
no sound comes out subwoofer sound
  • Audio Players & Recorders
