20 Most Recent
Nikon Digital Camera Coolpix S520 8MP Graphite Black + 4GB Deluxe Accessory Kit (ANIKCPS520GBK2) Questions & Answers
Nikon CoolPix S520
Good day,<br /><br />It sometimes happen that you lose your cameras user manual.<br />This can be very frustrating as you need to look up something, but you can't seem to find a manual anywhere!<br /><br />Well if you follow <a href="http://www.retrevo.com/s/Nikon-S520-Digital-Cameras-review-manual/id/13744ag300/t/1-2/">THIS </a>link you can download your cameras user manual on your computer and thus keep a digital copy handy for all the times you need it.<br /><br />Please let me know if this information was helpful!<br /><br />Kind Regards
How do you download pictures to the computer?
when you plug in the camera with cable to the pc , apear a window, you need just to open the file and search what file had a pictures, selection all pictures that you want to download to the computer and copy and paste the picture to the pc in a new created file
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue:
Remove the battery from your camera.
Fully charge the battery using the Nikon D80 battery charger.
Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover .
If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f....
Most of the time, this
F Error message is limited to Nikon DLSR cameras. This particular
error message appears when the camera is not able to communicate with the lens.
To
fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place.
If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center.
I'm not a camera buff but I thought I'd pass this on.
other sites too....
https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web
Best to you.
How to collimate Nikon Venturer II10x23 6.3 degrees compact binoculars?
Here are the steps to collimate your Nikon Venturer II10x23 6.3 degrees compact binoculars:
1. Adjust the diopter: The diopter adjustment is usually located on the right eyepiece, and it helps to adjust the focus of the image for your right eye. Close your left eye and adjust the focus of the right barrel using the diopter adjustment until the image is clear.
2. Look at a distant object: Choose a distant object, such as a building or tree, and focus on it using both barrels. Keep your eyes on the object while you perform the next step.
3. Adjust the barrel alignment screws: The barrel alignment screws are located on the hinge that connects the two barrels. You may need a small screwdriver to adjust them. Use the screws to adjust the alignment of the barrels until the images in both barrels are aligned. If the image on the right barrel is above and to the right of the image in the left barrel, you need to adjust the right barrel downwards and to the left.
4. Test your binoculars: Once you have adjusted the alignment screws, check the alignment of the barrels again by looking at a distant object. If necessary, make further adjustments until the images are aligned.
5. Repeat the process: Over time, the alignment of your binoculars may shift slightly, so it's a good idea to check the alignment periodically and make adjustments as needed.
Nikon coolpix s210 displays out of memory on screen, cannot take pictures.
Out of memory could mean that your memory card is full and you cannot take any additional pictures until you either replace the card with a new one, or delete or reformat the card you have in it. It could also mean that your card is "locked". Check for the little toggle switch on the side of the card to be sure it is in the "unlocked" position. Or it could mean that you do NOT have a memory card in the camera at all and you're using the very small internal memory your camera comes with (it usually will only hold about 4-5 images. If this is the case, put an external memory card in the camera.
Film camera turns off when I press the shutter button.
There are a few potential reasons why your camera might be turning off when you press the shutter button:
- Battery issues: Even if you just replaced the battery, there could be a problem with the connection or the battery itself. Try cleaning the battery contacts and making sure the battery is properly inserted.
- Jammed lens: If the lens is jammed or stuck, it could be causing the camera to shut off as a safety measure. Try gently turning the lens to see if it moves freely or if it's stuck.
- Faulty circuitry: If there is an issue with the camera's circuitry, it could be causing it to shut off when you press the shutter button. This would likely require professional repair.
It's also possible that the problem is related to the new roll of film you inserted. Make sure the film is properly loaded and that the camera is advancing the film properly. If you continue to experience problems, it may be best to take the camera to a professional for repair or to consider purchasing a new camera.
