20 Most Recent
Boston Acoustics BA7500 Computer Speakers Questions & Answers
Im not getting any sound or anything do i need to
try the above advice, but also check that your speaker volume is not muted. You would see a "speaker icon" on the bottom taskbar of your Windows screen. :-)
Adjust by sliding the bar up after you point the cursor on the icon.
BA7500g speakers won't work with my mac
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a a standard toslink cable with a toslink mini-plug adapter.
Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.
good luck. hope this helps
Wont play sound on my gateway model 6332
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer: hope this helps you:
DigitalBA7500G
No sound coming out of
settings there
also
untick it
problem
adjust volume
connection is good
causes static to build up in a computer hope this
helps
I have Boston Acoustics BA7500G
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bithope this helps
