20 Most Recent
Frigidaire FDR30S1 Dehumidifier Questions & Answers
Hello, we are having some trouble with our
Generally, most humidifiers work best between 60 -80 degrees . There is a model that is called a Low Temp model, that's designed for low temperatures in basements.
As far as your problem is concerned, t
here are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually
controlled unit, set the Manual Control Knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air
temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.I hope this helps you troubleshoot and solve the problem. Thanks for choosing FixYa.
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..
How to locate and replace internal filter?? For frigidaire
Good Afternoon Friend,
I understand that you are trying to locate and replace the internal filter for your Frigidaire dehumidifier, model# LAD304NUL. I also see that you cannot find your manual. To locate and replace the filter, follow these easy steps.
a. Remove the filter every two weeks based on normal operating conditions.
b. To remove the filter, remove Bucket then pull filter downwards.
c. Wash the filter with clean water then dry.
d. Re-install the filter, and then replace Bucket.
I have also included the link for your manual, where I found these instructions. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
