20 Most Recent Polaroid t1235 Digital Camera Questions & Answers
0answers
Does it charge when it is plugged into the computer?
Yes, if the computer's USB port puts out enough current. Not all USB ports do so, especially if you connect through a hub.
9/4/2012 7:30:59 PM • Polaroid t1235... • Answered on Sep 04, 2012
HOW CAN I TRANSFER POLAROID T1235 PICTURES TO MY PC?
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
2/6/2012 2:25:37 AM • Polaroid t1235... • Answered on Feb 06, 2012
Have polaroid t1235 dig. camera it won't transfer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
4/10/2011 3:47:14 AM • Polaroid t1235... • Answered on Apr 10, 2011
T1235 camera - battery is
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/11/2010 8:27:05 PM • Polaroid t1235... • Answered on Oct 11, 2010
When turning the camera on
Please help us solve this problem. My Polaroid camera also is in the same situation. The picture isn't blurry though, but yeah, camera can't be turned off unless the battery is taken out. Is this a battery problem? -J.
9/30/2010 7:08:39 AM • Polaroid t1235... • Answered on Sep 30, 2010
2answers
My polaroid t1035 touch camera the on button won't stay on
Power supply unit fault. need servicing.
3/27/2014 1:40:42 PM • Polaroid T... • Answered on Mar 27, 2014
Polaroid iSO48 Waterproof 16MP 4x Optical Zoom Digital Camera. I have an issue I think, when I watch a video that was recorded with the camera? It sounds like a constant "pip pip pip".
Question edited for clarity. This noise is more likely coming from the whatever is playing the video that than the camera recording itself. I have seen on old VCR machines. Play the video on something else to test.. https://www.google.com/search?q=Polaroid+iso48+video+makes+noise ..
2/25/2024 11:22:01 PM • Polaroid Cameras • Answered on Feb 25, 2024
Polaroid PDC 4055 Digital compact Camera. It won't display what's on the lens and keeps flashing a red light.
Question edited for clarity. Did you put in brand new certified fresh NiMH or Lithium Batteries? Opening the lens and powering the screen take the most milli-amps. The red light flashing is likely telling you the battery is flat. Did you check the manual? It has a Power LED. https://www.manualslib.com/manual/131605/Polaroid-Pdc4055.html?page=2#manual https://www.google.com/search?q=Polaroid+pdc+4055+battery https://www.google.com/search?q=Polaroid+pdc+4055 ..
9/10/2023 5:52:46 PM • Polaroid Cameras • Answered on Sep 10, 2023
I need a manual for my Polaroid i20x29
7/26/2023 1:30:04 AM • Polaroid Cameras • Answered on Jul 26, 2023
How do I review the sd card on Polaroid i534
4/13/2023 7:49:38 AM • Polaroid Cameras • Answered on Apr 13, 2023
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
2/5/2023 6:29:22 PM • Polaroid Cameras • Answered on Feb 05, 2023
Polaroid Land Player. The cassette in it will not eject.
Polaroid Land Camera or Polaroid Polarvision Player? https://www.google.com/search?q=polaroid+land+player%2C+cassette+won%27t+eject If it is Polarvision, it is an antique from 1977 and really shouldn't be used. https://www.google.com/search?q=polaroid+land+player&rlz=1C1QJDB_enCA643CA644&sourceid=chrome&ie=UTF-8 ..
1/11/2023 11:45:53 PM • Polaroid Cameras • Answered on Jan 11, 2023
Can't Find Polaroid iE826 Battery Replacement
Batteries do seem to be available and they do look like phone batteries. Just make sure the voltage is okay and that the MAh is the same or higher. https://www.google.com/search?q=Polaroid+iE826+battery+replacement ..
12/21/2022 7:16:19 PM • Polaroid Cameras • Answered on Dec 21, 2022
Reset date on iE826 Polaroid
See previous response to the same question
10/21/2022 6:56:54 PM • Polaroid Cameras • Answered on Oct 21, 2022
How do I connect my Polaroid speaker to sd card
First check whether your speaker has a slot for SD card if it is present then plug the SD card into the slot
1/16/2021 7:14:09 AM • Polaroid Cameras • Answered on Jan 16, 2021
Polaroid iS126 rapid battery drainage
This camera is known for that. Save your money and buy something with rechargeable battery
2/19/2020 2:21:49 AM • Polaroid Cameras • Answered on Feb 19, 2020
Polaroid t1235 Digital Camera Logo
Popular Tags
7 questions posted
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Bill Eager
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
T Polaroid
  • T Polaroid
Most Popular Question
charge when plugged into computer
  • Cameras
