20 Most Recent
Polaroid a330 Digital Camera Questions & Answers
I have a Polaroid a330 and just bought a 2GB sd
first try to see if the card is not locked from the side ..It has a little button that locks it ...after that insert the card into a computer with a card reader ..and format it in Fat mode...by opening my computer folder...right click on the removable storage device ...and choose format ...when it opens choose Fat ..and quick format ..than OK ..this will format it for the first time ..and after that isert it in the camera and see if it is seen ..
if the format card is not available now..(to format it in the camera again and be sure it is the right way and make the folders fro storage ) ..
goto storage feature in the main menu ..and choose to store in teh card ..in tis moment will prompt you to format ...or ..just choose a picture from the camera memory in the view mode..and options ..and try to move it in the card ..if it is not proper formatted will ask you to format it ..and give you the possibility to make it right the way by asking you if you want to format it now...choose ok..and that's all..But I suspect that if you unlock it ..and format it in a computer will work like a charm ...
Green light flashing on Polaroid iE 6035
The green light flashing on your Polaroid iE 6035 camera typically indicates that the camera is in standby mode or that it is charging. If the camera is not charging, it could be a sign of a problem with the battery or charging mechanism. If the green light continues to flash even after charging, it may be necessary to take the camera to a professional for repair or to have the battery replaced. Before seeking professional help, you can also try resetting the camera or removing and reinserting the battery to see if that resolves the issue.
