20 Most Recent ION Audio iPROFILE LP to iPod DJ Conversion Turntable Docking Station Questions & Answers
Im trying to sinc my
No, unfortunately the device was only meant for LP to iPod or LP to computer type connections, and doesn't support normal itunes syncing.
3/1/2011 2:22:36 PM • ION Audio... • Answered on Mar 01, 2011
Trying tocopy album direct to i pod sound quality
Hi, you need to use a pre amp between the turntable and ipod to up the output. Alternatively you can run it through a mixer or amp with dedicated phono input. styluscity@gmail,com
9/13/2010 8:28:09 PM • ION Audio... • Answered on Sep 13, 2010
0answers
My turntable appears to be uneven. it looks like a rolling hill when spinning, can this be fixed
Is it just the matt that records sit on that's the problem or the whole platter? If it is the matt you can peel it off and get a new one from somewhere such as as Amazon. It doesn't have to be the same brand as the turntable as long as it fits on. Just search for "turntable matt". If the platter is the problem it might be caused if the platter is plastic by either a chemical or heat warping the platter. Has it been exposed to the sun for example? Some chemicals such as oil and polish can cause it to bend out of shape. It's likely if the platter has warped that it will need to be replaced.
5/22/2015 11:16:46 AM • ION Audio Audio... • Answered on May 22, 2015
Mitsubishi x7 turnable
Yes.
4/3/2015 5:18:39 AM • ION Audio Audio... • Answered on Apr 03, 2015
Record vinyl to my mac from numark pt-01
Try this software. Audacity it's free. Audacity Mac OS
6/23/2014 8:48:58 AM • ION Audio Audio... • Answered on Jun 23, 2014
0answers
I need a power adapter for the ion audio quick play flash...
Buy a multi voltage adapter online.
1/10/2014 10:43:55 PM • ION Audio Audio... • Answered on Jan 10, 2014
2answers
Will the Ion Turntable work with Windows 7? I only
If your ION turntable is a USB basedwith a USB plug it will work. Just plaug it into your USB posrt. A driver may need to be downloaded from the ION website for windows 7
12/2/2012 5:59:33 PM • ION Audio Audio... • Answered on Dec 02, 2012
Rumbles badly, unable to play.
Adjust the weight on the end of the arm, till the rumble sounds stops, but the stylus stays in the groove. It's trial and error doing this I'm afraid.
9/15/2011 12:27:31 AM • ION Audio Audio... • Answered on Sep 15, 2011
I can play LPs, b ut when I click on "record", and
Uninstall the upper and lower filters scroll down to how here: support.microsoft.com/mats/cd_dvd_drive_problems
Also, this can be as easy as your burning software as have that problem allot. Download the below ad try doing something on the drive: www.nero.com/eng/downloads-nero8-trial
Hope helps.
8/6/2011 11:06:53 PM • ION Audio Audio... • Answered on Aug 06, 2011
I tried hooking up my
You don't actually say to WHAT, or if you used the applicable manual(s)... It does take two to tango, you know.
You might find the manual for the TT here...
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=ion+turntable
4/19/2011 9:29:16 PM • ION Audio Audio... • Answered on Apr 19, 2011
0answers
I have connected my Akai AP A510 turntable to my
"PHONO" is the only designated connection on a receiver that is literal and exclusive. Nothing but PHONO will work right on it and old-school turntables would require it to preamplify the tiny current produced by a Phono cartridge.
If your unit doesn
2/21/2011 8:52:53 PM • ION Audio Audio... • Answered on Feb 21, 2011
I have been transferring cassettes to my Mac with
I suspect your mac has the microphone mixing in with other inputs. BIG BROTHER may be lstening, too. Find your mic control and turn it off.
2/13/2011 8:24:24 PM • ION Audio Audio... • Answered on Feb 13, 2011
ION Audio iPROFILE LP to iPod DJ Conversion Turntable Docking Station Logo
3 questions posted
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
John
John
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • ION Audio Audio Players & Recorders
Most Popular Question
im trying sinc
  • Audio Players & Recorders
