20 Most Recent Toshiba TEC BSX5 Thermal Label Printer Questions & Answers
Print moves up label
Check the size, check if you have selected dectect transmission
12/9/2013 1:53:59 PM • Toshiba TEC BSX5... • Answered on Dec 09, 2013
TEC BSx5 - need to update firmware
In the diagnostics menu choose ramclear and parameter clear should do the trick
12/9/2013 12:47:44 PM • Toshiba TEC BSX5... • Answered on Dec 09, 2013
0answers
0answers
Lower guides not moving in ratio with each other
Two ways:
Either you uncrew the guides and put the back correctly or
Press on the black on or pull gently on the green one so that it will be forced back in its original position. In fact someone pulled or pushed on the guides and they are no more correctly positionned
8/4/2011 2:50:30 PM • Toshiba TEC BSX5... • Answered on Aug 04, 2011
TEC B-SX5 USER INTERVENTION REQUIRED?
what is the exact meesage?
8/4/2011 2:47:26 PM • Toshiba TEC BSX5... • Answered on Aug 04, 2011
Our Tec SX5 is connected
Uncheck the bidirectional control in the port properties
8/4/2011 2:46:15 PM • Toshiba TEC BSX5... • Answered on Aug 04, 2011
Black ribbon is not back feeding same amount/speed
This is due to the quality of the ribbon.
When the paper moves back, since the head is not raised, the paper rubs on the ribbon en is the cause of the black smudge. Use correct Ribbon
8/4/2011 2:43:39 PM • Toshiba TEC BSX5... • Answered on Aug 04, 2011
Software reloaded = Teklynx Labelview Drivers
I looked this problem up on the net, and ran across this web blog. They suggest a procedure to try, and maybe it will help you:
http://www.centurysystems.com/techsup/faq/tecfaqs.htm#3
If that doesn't help, the sensor could be bad, and needling replacement.
Good luck, and hope this helps.
7/20/2010 3:42:40 AM • Toshiba TEC BSX5... • Answered on Jul 20, 2010
RIBBON ERRORS
Ribbon error message is displayed when the rotation of the ribbon spindle is not performed or not correctly detected. This can be due to various factors.
- The ribbon roll is not correctly fitted to the spindle.
- The sensors detecting the rotation are out of order or completetly filled with dust or grease.
In this case clean the sensors.
Another reason may be due to Direct thermal printing with a ribbon mounted.
9/3/2009 1:04:04 PM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
2answers
Zebra Z4m Barcode printer
That using these symbols. Select a better code 128A or B.
9/3/2009 9:40:59 AM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
Im getting paper jam printing
Check your label size, type of sensor and try to recallibrate the printer. In case of preprinted labels do as in the owners manual for preprints and select this function in the driver.
9/3/2009 9:38:02 AM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
Printer driver
Yes you have to have a driver or send tpcl commands
The other solution is to install a cups driver.
9/3/2009 9:36:17 AM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
2answers
Euro Symbol Printing
0128 is not a recognisable sysmbol Go to the Toshiba web site and the tech Support team- evidently there has been an error in the printed instruct as to the symbol number.
9/3/2009 9:27:57 AM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
Why do you want to disable these buttons?
In case of problems during printing you need them.
You can just unplug the cable and yours buttons will be inactive.
9/3/2009 9:26:19 AM • Toshiba TEC BSX5... • Answered on Sep 03, 2009
Ribbon error on B-EX4T1 with direct thermal labels
First of all, With any Toshiba label printer, after a parameter reset, you must send a label before doing a feed. Otherwise the printer will try to feed the ribbon. You can use the setting tool to tell set the printer to direct thermal also. Easiest way is to use the windows driver , add a label format coresponding to the one you are using, verify in the support tab that you are in direct thermal, do a test test print from the driver and you'll solve your problem
7/3/2019 3:36:24 PM • Toshiba TEC... • Answered on Jul 03, 2019
Toshiba TEC B-472 printing only top half of label
Perform hard reset of electronics and also re install the driver.
9/17/2017 10:36:38 AM • Toshiba TEC... • Answered on Sep 17, 2017
Toshiba TEC BSX5 Thermal Label Printer Logo
20 questions posted
Top Toshiba TEC Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba TEC Office Equipment & Supplies
Most Popular Question
ribbon errors
  • Office Equipment & Supplies
