20 Most Recent
Toshiba TEC B-572 Printer Questions & Answers
Printing on TEC b-572 pauses
DEFAULT SPEED IS 9600 bauds, 8 data bits , 1 stop bit no parity.
Un fortunateley the best spped avaible is 19200 bds.
The pausing is due to too much data transfered trough the serial port.
To sole this, increse tehe baudrate and use internal fonts.
Program load mode
check the dipswitches
Sw1-8 -on is for program downloadelse check if the 3 buttons on the front panel are not pressed.
- Your firmware is corrupted you have to dowload a new firmware
Printer display various error codes
You have a problem with data transmission.
May be due to cable problem or centronics interface.
Check using serial cable default 9600,n,8,1
Receiving error "No Paper" but
Have to callaibrate the sensors or you have a problem with the size of your label. The gag is in the sensor when printing starts or stops.
Use the tear option to try to correct this error or use a longer or shorter label.
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
I am testing an aold B-572 printer. If I print one
Check:
- The value of the Rbn adj Fwd and Bck value.
Check that you are in thermal transfer mode in the driver.
Check if yu don't have dusts on the synchro wheels (You have to open the printer electronic cover.
Ribbon breaking
Either to much heat or the support is unappropriate. Try to choose another ribbon quality
