20 Most Recent
Toshiba TEC B-452 Thermal Label Printer Questions & Answers
How to fix an error?
First of all check that the ribbon core is correctly placed with the notches fitting on the Green wheels. If th ribbon coe is not secured the wheel will not turn and no ribbon will be detected. If your core is too short and with no notches, you'll have to glue a pice from another core an create a notch.
When i press the feed
Send the correct length to the printer.
Use a windows driver to sent a test page at the correct size and dectection
My tec b452 printer is
Check that you are not in direct thermal mode and if the roll is correctly placed on the supports. If the roll is not meant for this printer then you have this error
How do you do a printer report on the 452 toshiba
Swtch on with pause key depressed and wait for the power and online leds blinks and error led off.
To cahnge from thertransfer or direct printing mode depress feed and pause spontaneoulsy.
By depresing feed the self test is printed
