20 Most Recent Kenwood KDW243A Builtin Dishwasher Questions & Answers
4answers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
8/22/2021 6:02:10 PM • Kenwood KDW243A... • Answered on Aug 22, 2021
2answers
What is E1 error code
The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
9/8/2019 10:11:08 AM • Kenwood KDW243A... • Answered on Sep 08, 2019
Hi there program lights come on and then go straight off and won't give me the option to select any program can you help?
The door latch is not catching and pulling the door closed all the way. It may be loose or broken. This means that you need to remove the cover panel on the top of the door and the catch mechanism to get them aligned correctly
1/11/2016 6:11:29 PM • Kenwood KDW243A... • Answered on Jan 11, 2016
0answers
What does E4 message mean
It means your leak detector has detected a leak.
12/7/2014 2:41:52 PM • Kenwood KDW243A... • Answered on Dec 07, 2014
2answers
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
9/20/2014 1:29:50 PM • Kenwood KDW243A... • Answered on Sep 20, 2014
0answers
2answers
Kenwood dishwasher
You will have to remove it from its installed location. This means unhook the water supply and drain hoses. Then you pull the screws out that hold it to the counter top. Then slide the unit out until you can see the back. The rear legs usually screw in and out to raise and lower the unit.
8/1/2014 8:55:44 PM • Kenwood KDW243A... • Answered on Aug 01, 2014
0answers
Kenwood KDW243A Builtin Dishwasher Logo
105 questions posted
Top Kenwood Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenwood Dishwashers
  • Kenwood Dishwashers
Most Popular Question
kenwood dishwasher
  • Dishwashers
