20 Most Recent
Sony Ericsson Naite Cell Phone Questions & Answers
Sir i bought new sony ericsson naite cell phone /
You should be able to increase volume on the side of the phone though you probably already know that, but other than that you should talk to your operator. It might even be their problem in some way. Try calling different phones or you get try with a headset, and if the sound is still bad it has to do with the internals of the phone rather than the speaker or maybe your operator.
I want to know how
by resetting to factory setting you can format your phone memory
but be aware take your all contacts to your memory (by using backup option)
dont forget to vote me it will help.
Code memo password problem
during open code memo in my mobile Sony Ericsson j105i naite is showing wrong password. please get me out of these without loosing the data.Thanks & RegardsYaseen
I am sony ericsson j105i
Seems your fault can be related to a hardware issue in the mother board but just to take a possible solution to reset if the phone has hung up because there of errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Mic prb for j105i
Mic problem on the headset? You need to determine if it is. DO you have a problem when you attach bluetooth? Most likely not, but rule it out. Then try a direct microphone/earpiece. If you still have problems let me know. What we want to determine is whether this is a hardware (a problem with the actual microphone inside the phone, or if we have a software or configuration problem. I may not be able to get back until the morning, so only respond to this in the morning. That way it doesn't sit out here unanswered for 12 hours. That's frustrating for you. It's 10:30 here and I'm fixin to go to sleep in an hour or so.
Billy
