20 Most Recent HTC Droid Eris by Questions & Answers
1ST ISSUE NOW RESOLVED, MY PHONE CALLS AND TEXT MSGS/VMAILS WERE GOING TO THIS GUYS PHONE THAT I WENT ON A DATE WITH?? I WAS ABLE TO GET THE CALLS COMING BACK TO ME AND TEXTS.. BUT WHY IS IT WHEN I D
Well I would suggest to do a backup of your contacts and sms messages and just do a HARD RESET on your phone to put it back to the condition that you first got it. After that if he installed any software or Buletooth linked your phone to his it will be all GONE and you can restore your contacts and sms messages Hope this helps and IT WILL WORK if you do this
3/9/2017 8:26:50 AM • HTC Droid Eris... • Answered on Mar 09, 2017
9answers
I want to lock texts and delete unwanted ones
You select the text message that you want to lock, hold your finger on the message until a menu appears and scroll down to lock message. Once locked a lock should appear in upper right hand corner.
Then you can select the thread of messages that you want to delete from the list, check the box that states you want to delete all messages including the locked ones.
1/26/2017 3:41:52 PM • HTC Droid Eris... • Answered on Jan 26, 2017
2answers
My droid eris is running very slow. Anything i do ...
If you don't have it, I recomend the Advanced Task Killer App. It force closes any program running in the background making things run more smoothly.
11/30/2016 1:58:33 AM • HTC Droid Eris... • Answered on Nov 30, 2016
My DROID ERIS by HTC had a factory reset how do I fix that
You cannot turn back a factory reset
11/26/2014 8:36:08 PM • HTC Droid Eris... • Answered on Nov 26, 2014
Moto G text signature
Actually it does, see below: To add a signature to each sent message: 1. Select OK > Messaging > Settings > Text Messaging. 2. Highlight the Add Signature field. 3. To have your phone add your name to each text message, select On. - or - To have your phone add a custom signature to each text message, select Change Signature, enter the closing you want to sue, and press save (left soft key)
4/6/2014 3:03:52 PM • HTC Droid Eris... • Answered on Apr 06, 2014
Locked q mobile noir A6 by enter wrong pattran
hi... of course give ur mail address then automatically the pattern sent ur address...
4/5/2014 6:43:13 PM • HTC Droid Eris... • Answered on Apr 05, 2014
3answers
Forgot lock screen pattern takes me to username
IDK about a simple legitimate fix for this. I was just messin around with the pattern, hit "forgot pattern" to see what it does. It asks me for the Google username and password, but has no way for me to go back! I know the pattern! The Motorola Droid is free from this problem, when on the forgot password screen, it still allows me to go back to the pattern screen. Very disappointing HTC...
On the other hand, there is a bit of a "hack" that can be used to solve this. Create a new Google account. Then call the locked phone from another phone. While in the call, you have full access to the phone. Press home, go into your settings, and add your new Gmail account into the phone. End the call, go back, and enter your new Gmail info. You may also need to enable Wifi while the call is still connected, I'm not sure if 3G will work for the sync while the phone is "locked".
4/5/2014 1:10:35 PM • HTC Droid Eris... • Answered on Apr 05, 2014
Locked out of my from my pattern
Factory reset(but this will erase all your user data) unless your phone is rooted and have USB debugging enabled and know how to use ADB, then you can pull the gesture.key from the phone memory and use rev skills to brute force it.
12/7/2013 12:48:46 AM • HTC Droid Eris... • Answered on Dec 07, 2013
How to unmute keyboard on htc eris
Go to Settings>Sound>tick Touch sounds box
11/4/2013 3:01:25 PM • HTC Droid Eris... • Answered on Nov 04, 2013
My touch scrren is not working well
go to settings and calibrate it
8/21/2013 10:20:12 AM • HTC Droid Eris... • Answered on Aug 21, 2013
My htc adr 6200 touchscreen didnt work
press vol up + power... a dos flash screen will appear.. the choose wipe factory or update touchscreen firmware... :)
1/19/2013 5:44:28 PM • HTC Droid Eris... • Answered on Jan 19, 2013
How to unlock verizon phone
Unlock Cell Phones Your cell phone may be locked to a particular cell phone provider and in this case it needs to be unlocked to use with a different cell phone service provider. To get the security code/restriction code to unlock the cell phone from the current cell phone provider so you can use the SIM card with a different phone provider, Please click on this link and follow my instructions :- http://www.fixya.com/support/r4049238-unlock_cell_phone If your phone provider does not help you then these WEB sites it provides security codes for a small price. http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw http://www.mobileunlocksolutions.com/ http://www.superunlockcodes.com http://unlockcellphonecode.com/
1/19/2013 4:56:52 AM • HTC Droid Eris... • Answered on Jan 19, 2013
I charge my eris all night and only gets 40% life
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
8/21/2012 6:22:37 AM • HTC Droid Eris... • Answered on Aug 21, 2012
I have htc droid eris
YOU CAN UNLOCK YOUR HTC CDMA PHONE HERE THIS SITE. THIS SITE OFFER BEST PRICE FOR HTC UNLOCK CODE. I HOPE THIS WILL HELP YOU ALOT.
9/23/2011 2:13:08 PM • HTC Droid Eris... • Answered on Sep 23, 2011
3answers
I need an unlock code for a htc droid eris
Codes are the best way for unlocking phones i know the site which provides good services.i got my unlock code there.hope you will also find yours.click here to get your unlock code.
hope this helps..
8/15/2011 10:49:41 AM • HTC Droid Eris... • Answered on Aug 15, 2011
0answers
HTC eris screen is froozen!
Frozen Screen problem mostly occurs when one has recently updated the phone software.
If that's the case with you taking battery out should have helped.
Try resetting it this way.
> Turn the power off. Take the battery off and then re-insert it.
> Hold the Volume Down button
> Hold the Power button until the display turns on
> You are now presented with a menu that allows for Clear Storage.
> Select Clear Storage by pressing the Volume Down button
> Press and release the Power button to select
> Press Volume Up for Confirming your action.
>>> If you selected YES, the phone will reboot to its factory fresh state and would also wipe all 3rd party applications.
5/25/2011 2:43:34 AM • HTC Droid Eris... • Answered on May 25, 2011
How do I get to where you put your name as your
Click your text messages icon, then the menu button, go to settings from there and scroll down. You should see an option to display a message signature.
Hope this helps!
-Zach
5/6/2011 9:53:49 PM • HTC Droid Eris... • Answered on May 06, 2011
HTC Droid Eris by Logo
91 questions posted
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
HTC Cell Phones
  • HTC Cell Phones
Most Popular Question
touch scrren not working
  • Cell Phones
