20 Most Recent
Tomtom GO 750 LIVE GPS Receiver Questions & Answers
Voice somtimes not work
wrong voice installed, they come in 2 versions. 32mb or 64mb depending on model of the tomtom unit. downloading off share sites and just installing is not allways the right way
Find reset button on tomtom go 750
The reset is done by pressing and holding the On/Off button until you hear the drum sounds and the device restarts. This can take 30 seconds or more.
Tomtom 750 live has died !! cant switch on!
First, check and make sure your battery is fully charged. Then try to do a "Reset" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.To navigate to a location using latitude and longitude
coordinates, follow the steps below:
- From the Main menu, tap Navigate to...
- Tap Latitude Longitude.
- Enter the coordinates and tap OK.
Server error 1502
There is an intermittent server issue that is causing an Error 1502 on some LIVE devices, temporarily preventing access to TomTom LIVE Services.
We are aware of this and investigating with high priority.
When trying to go to the any live service on the
I had a similar issue, I just used an old PAYG SIM and swapped it to fix the problem. The cover is held on by 4 screws, once open the old SIM card pulls-out without any further dismantling. You still need to subscribe to get live services though.
Just bought a tomtom live
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others.
How to convert from feet and inches to metric?
Click the screen to access main menu this should bring up the ability to click change preferences and then in that menu you should be able to scroll through and find the option to change from feet and inches to metric.
