20 Most Recent Sanyo DP32649 31.5 in. TV Questions & Answers
Pull up the menu. Go to the Picture Menu. Click Manual. Then go to Detailed Sertings. Once there, scroll down to the V-size & H-size to adjust them to your desired settings.
Sanyo DP32649... | Answered on May 15, 2019
check the fuse may have blow up
Sanyo DP32649... | Answered on Sep 26, 2016
Check the power plug for power. If this is OK then you likely have a blown TV power board, and the primary components are affected. The caps in the primary circuit can be replaced if they are blown, but otherwise you may need a new board.
Sanyo DP32649... | Answered on Jan 19, 2015
Check the TV for a PC input cable. This can be the HDMI cable input and will work to have a HDMI cable from your Acer to your TV, no diagram is needed.
If the cracked portion is on the cable then you need to get the cable recrimpted with another connector. You can do this yourself but this needs a special tool. Ask your cable provider to get the proper connector reapplied.
This definitely means that you have no signal input to the TV. Check the signal input and switch to the source input that you provide, like cable or antenna.
Sounds like your main board will need to be replaced.
Check the colour settings in the menu. This is an easy fix when you select the proper settings.
This is not necessarily the fault of the TV but the audio feed signal going to the TV. Note that in most cases the commercials are louder than the actual programs you watch.
You need a new main board or a service of the existing one.
For 32'' models probably a replacement will be easier.
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ .
Yes, it's the lamp. Order one from your local electronics repair shop. Or toss your Sanyo TV in the garbage and buy something new
This is likely a power board failure. Check that this board has blown caps and replace the caps with the exact part and make. This is usually a $10 fix.
Sanyo DP32649... | Answered on Jan 02, 2015
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Sanyo DP32649... | Answered on Apr 02, 2014
Some TVs allow closed captioning to be selected during initial set up. You may have to return to the initial setup procedure and select CC.
Sanyo DP32649... | Answered on Dec 01, 2013
Sanyo DP32649 31.5 in. TV Logo
78 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
no 3 3 volts blon
  • Televison & Video
