20 Most Recent
Sungale DVD9800 DVD Player Questions & Answers
Keeps sayin wrong disc
If your device is a new one, it should be a factory error. You should return it back to the supplier. However, if the device just developed the fault, I will suggest 2 basic faults and their solutions:
1. As a result of insufficient or too much electric power for use by your device. You should make us a stabilizer or a step-down device.
2. As a result of a faulty lens, which is usually the major in most cases. If after trying step one it continues, then I must say that your lens has some questions to answer,hmmm. Hope this helped.
4/21/2011 7:33:35 PM •
Sungale...
Answered
on Apr 21, 2011
I have dvd2026.the door will
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer. Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
6/9/2010 9:57:29 PM •
Sungale...
Answered
on Jun 09, 2010
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
