20 Most Recent
Nokia 5130 XpressMusic Red Unlocked Import Cell Phone Questions & Answers
How i fix network on nokia expresmusic
if the mobile is fall down or wet than its need deep service with special liquid if not than check PFO, if Ok than make a Jumper from antenna switcher to connecting Pad
My Nokia 5130-2c is just displaying "test mode" I don't know wat to do
There are few things you could try. Make sure you try from top to bottom and one method at once
Method 1 > Factory reset your device.
Method 2 > Flash an updated firmware
Method 3 > This requires some technical assistance. you better hand it over to a skilled technician as this deals with hardware level repairing
I have 5130 expressmusic in this mobile internet
try to contact your cellular data provider ask tem to activate the GPRS\EDGE for your mobile no they'llsend the settings through SMS save it and then try to browse it'll work..
hope this helps your need
I delete some photos in my Nokia 5130. which is get from bluetooth how can i recover
Good day my friend! You need to connect your cellphone to the computer by connecting with your USB cable. When the computer detected your mobile you may now proceed to the next step. Download this free but very useful software that will help you to recover your deleted photos. But before you do that it is important that you did not save any mp3 or taking pictures that saved after you accidentally deleted. Because it is very hard to recover especially from the flash memory card. But in that case try your best of luck, here is the software that will help you to recover.
Recuva Undelete Unerase File and Disk Recovery Free Download click this link and it will directly connect to this website, click the download button to download the software and after downloading just double click the software and follow the screen instruction.
Recuva Screenshots here the link for screenshots while performing the data recovery. Have a good day!!!!
Forgot my security code for
Use the default code which is 12345 or 00000, but if it does not work then you will need to send me the imei of the phone so i can help you out with a master code.
thanks.
How to reset
Type *+3+call+power on button. Default lock code is 12345
Restriction code nokia 5130
hi you can use codes to unlock the mobile you can get the codes from here
mobileunlocksolutions here they ask the following details before providing the codes they are mobile model
country and the provider to which the mobile is locked .you can get the instructions about how to use the codes in your
mobile from here
mobileunlockguide here they provide the step by step process about how to use the codes
once you entered the codes in your mobile as for the instructions given your mobile get unlocked and will be free to accept all
network sim.
