20 Most Recent
Xante FilmMaker 4 Printer Questions & Answers
Film maker 4 laser printer, paper tray feeder keeps going up and down, even on a 1 colir or multi-color separation.
One potential issue could be that the paper feeder is not properly aligned. Try opening up the printer and checking to see if the paper feeder is properly seated and aligned. If it isn't, try adjusting it until it is. If this doesn't fix the problem, there may be an issue with the sensors or actuators that control the paper feeder. Check for any loose wires or damaged parts. If you find any, try repairing or replacing them as necessary. If all else fails, you may need to replace the paper feeder itself.
Xante ilumina 502 network menu lost
If the network menu is lost on your Xante Ilumina 502 printer, it may be possible to restore it by resetting the printer's network settings. Here are the general steps to reset the network settings on the Xante Ilumina 502:
- Power off the printer.
- Locate the network card on the back of the printer.
- Press and hold the small button on the network card for 10-15 seconds. This will reset the network card to its default settings.
- Power on the printer.
- Press the "Menu" button on the printer's control panel.
- Use the arrow keys to navigate to the "Network" menu.
- Select "TCP/IP" and then "DHCP" to ensure that the printer is configured to obtain an IP address automatically from your network.
- If your network requires a static IP address, you can manually configure the IP address and other network settings in the "TCP/IP" menu.
- Save your changes and exit the menu.
