20 Most Recent
Nortel Networks 7220 (NTE350BG) 802.11 Wireless Access Point Questions & Answers
I want to factory reset
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
How do I unlock voicemail on a hand set?
Enter the admin mailbox (usually FEATURE 981). Follow the prompts to enter the mailbox change menu for the box you need to reset and select the "reset password" function. This unlocks the box and sets the password to 0000, which will then prompt the user to enter a new password when the mailbox is opened. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/dave_fb2c45146b845cea
