20 Most Recent Motorola AP300:802.11A/G, Internal Antenna (WSAP-5110-100-WWR) 802.11a/b/g Wireless Access Point Questions & Answers
3answers
I have a motorola AP-300
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
4/22/2014 4:16:24 PM • Motorola... • Answered on Apr 22, 2014
We have a router motorola
Hmmm, check if it shows up as a network to connect to..... If so it might be an internal antenna.... If not, then you can find antennas on the internet, best bet from the place you bought the router.....
PS: I am assuming you have a Modem?
1/8/2011 10:27:35 PM • Motorola... • Answered on Jan 08, 2011
The MC 3300 scanner is frozen on a white background that has a blue motorola symbol. and says MC33X series
If your MC3300 scanner is frozen on a white background with a blue Motorola symbol and says MC33X series, you can try a soft reset to see if that resolves the issue. To do this, follow these steps:
  1. Hold down the power button until the scanner turns off.
  2. Wait a few seconds, then press the power button again to turn the scanner back on.
If the scanner is still frozen after attempting a soft reset, you may need to perform a factory reset. Please note that performing a factory reset will erase all data on the device and return it to its default settings. To perform a factory reset on the MC3300 scanner, follow these steps:
  1. Press and hold the power button and the volume down button simultaneously.
  2. Keep holding both buttons until the scanner vibrates and the Motorola logo appears.
  3. Release both buttons.
  4. Use the volume buttons to navigate to the "Factory Reset" option, and then press the power button to select it.
  5. Confirm that you want to perform a factory reset by selecting "Yes" using the volume buttons and pressing the power button to confirm.
  6. Wait for the scanner to reset and restart. This may take a few minutes.
If a factory reset does not resolve the issue, you may need to contact Motorola's customer support for further assistance.
2/24/2023 9:51:25 PM • Motorola... • Answered on Feb 24, 2023
Battery replacement for a Motorola S10-HD Bluetooth Headset
Your best bet is to ask in a mall phone repair shop. They do jobs like this at a very reasonable cost. The battery is $10 plus postage. https://www.aliexpress.com/i/33047313596.html ..
10/25/2022 8:09:45 PM • Motorola... • Answered on Oct 25, 2022
Motorola tracphone galaxy iPhone A12
It can't be a Motorola, a Tracphone, a Samsung Galaxy A12 and an iPhone! That is 4 different makes. The unlock for Motorola depends on the model and age. The Tracphone and the Galaxy is a standard Android hard reset. The iPhone is hard reset using iTunes on a computer. If it is a PUK Lock, this applies. https://www.fixya.com/support/r26056685-phone_asking_puk_code ..
10/11/2022 11:01:55 PM • Motorola... • Answered on Oct 11, 2022
Can you help me charge my motorola 1090-HC1
Thanks for your question. i have found your product charger. https://www.ebay.com/itm/373817273263
10/8/2022 5:50:12 AM • Motorola... • Answered on Oct 08, 2022
I don't have the plug and need to make my own but need T605 power plug pinout
Check amazon.com or ebay.com
5/1/2022 3:04:06 PM • Motorola... • Answered on May 01, 2022
Motorola Comfort 75 Monitor Issue
You should be taking it to a local hardware repair store to get it checked out. Most probably, the panel has gone bad.
11/29/2021 12:41:04 PM • Motorola... • Answered on Nov 29, 2021
4410md default password
Buen d?a tengan todos, se tienen unos equipos Motorola DSR 4410 MD, DSR 4460 y DSR 6100, los cuales cuentan con puerto 10/100 para gestion y configuracion remota, nos pueden facilitar el login y password ya que al ingresar por el explorador el equipo solicita clave de acceso. quedo atento y gracias por su ayuda.
11/8/2021 8:55:47 PM • Motorola... • Answered on Nov 08, 2021
2answers
I forgot my password and username of motorola CPEi 35600 router. how to get run my router
192.168.15.1 try motorola for password or CLEAR123
10/29/2021 3:26:59 PM • Motorola... • Answered on Oct 29, 2021
My IWAVE SP58083 SoloAudio Speaker has no sound even though paired to my Android how can I fix this
Tell the Android device to forget the speaker, then reboot both devices and pair again. Also make sure the volume isn't at zero!
8/4/2021 4:19:22 AM • Motorola... • Answered on Aug 04, 2021
2answers
How to download motorola bluetooth pc850 driver of wireless adapter
YOU CAN DOWNLOAD YOUR MOTOROLA BLUETOOTH EITHER FROM STORE APP OR GOOGLE APP.
12/7/2019 7:21:19 PM • Motorola... • Answered on Dec 07, 2019
When does Tally show the following Error : DR/CR
while splitting the company Error msg: voucher amount do not match
6/28/2019 10:37:38 AM • Computers &... • Answered on Jun 28, 2019
One of my two Motorola TLRK T4's generates a static white noise but the other one doesn't.
You didn't say whether the radio still worked ok apart from the noise... Defective components can produce such noise as can a dry soldered joint - a dry joint is a fairly common fault. A white type noise is typical of many types of receiver when the squelch is turned down. The squelch circuit is designed to reject signals that are too weak to receive with sufficient strength to be intelligible and in doing so also blocks the background "static". On many CB and VHF type receivers the squelch level is adjustable but tends to be either preset or automatic on basic walkie-talkie type radios. Perhaps the squelch requires adjustment or perhaps the circuit has stopped working.
6/9/2019 8:31:47 PM • Motorola... • Answered on Jun 09, 2019
Motorola AP300:802.11A/G, Internal Antenna (WSAP-5110-100-WWR) 802.11a/b/g Wireless Access Point Logo
4 questions posted
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Computers & Internet
Most Popular Question
motorola ap 300
  • Computers & Internet
