20 Most Recent
Sony SPP A2770 Cordless Phone Questions & Answers
How do you disable the recording after the 10th
If you want to disable your whole answering machine, then you need to take that up with your phone company. Otherwise, if you want to shorten the amount of rings it takes to get to the answering machine you can go into your options menu on your phone. You can also change your answering machine. Hope that helped! ~~RJ~~
How do I turn down the ringer volume.
For the base station set the ringer switch on the base from high to low. To turn it off select off. You can find that switch on the panel where the phone plugs into the wall on the far left.
The handset is adjusted the same way on the leftside as you are looking at the phone.
Hardware error w302
Love it cuz it makes it just mine...It's Good for usage by a friend who let's others to veiw my mobile and maintaining secrets of my own. Cause I can lock my apps and intercept harassment calls. It gives me the freedom of privacy
