20 Most Recent
Jaeger-lecoultre Jaeger Le Coultre Reverso 101 Art Deco Watch 3003431 Questions & Answers
Oakley screw fell out
Here are a few steps you can take to address this issue:
Tighten Existing Screws: First, try tightening the hinge screws. Use a small, flat-head screwdriver to remove the rubber screw cover located on the hinge area. Then gently tighten the screws that hold the hinge in place. Be careful not to over-tighten them, as this can strip the screws.
Check for Replacement Screws: You can search for replacement screws specifically designed for Oakley Tie Breaker sunglasses. Some online retailers offer Oakley replacement screws that can help fix the problem. Look for screws that match the original ones in terms of size and design.
Sunglass Repair Kits: Consider using a sunglass repair kit. These kits often include various sizes of screws and tools for repairing sunglasses. You might find a suitable replacement screw in one of these kits.
Remember to handle the screws carefully and avoid overtightening. If you're unable to find a replacement screw, reaching out to Oakley customer service.
4/20/2024 10:49:19 PM •
Clothing...
Answered
on Apr 20, 2024
What do you pack in your purse?
Here are list of things you can carry in your purse:
A makeup bag. I do my makeup on the go a lot, so a makeup bag is necessary for me.
A pair of earrings / jewelry.
Hair ties and bobby pins.
A hair brush.
A notebook / sketchbook.
A pen and a pencil.
Pack of tissues.
4/17/2024 7:09:47 AM •
Clothing...
Answered
on Apr 17, 2024
How to clean white shoes properly?
Cleaning white shoes can help maintain their appearance and keep them looking fresh. Here's a step-by-step guide on how to clean white shoes properly:Materials you'll need:1. Mild soap or detergent2. Soft brush or toothbrush3. White vinegar or baking soda (optional)4. Water5. Clean cloth or sponge6. Old newspapers or paper towels Steps:1. Remove Loose Dirt: Knock your shoes together or use a brush to remove loose dirt and debris. You can also use a soft cloth to wipe away any surface dirt.2. Remove Laces: Take off the shoelaces. You can either clean them separately or replace them if they are too dirty or worn.3. Pre-treat Stains:If there are stubborn stains, pre-treat them with a mixture of water and a small amount of mild soap or detergent. You can also use a paste made from baking soda and water for tougher stains.4. Soak Laces:If you removed the laces, soak them in a mixture of warm water and mild soap. You can also add a bit of baking soda or white vinegar to help with stains. After soaking, scrub them with a brush or toothbrush, rinse, and let them air dry.5. Wash Shoes: Mix warm water with a small amount of mild soap or detergent. Use a soft brush or toothbrush to scrub the shoes gently. Pay extra attention to stained or dirty areas. Be careful not to use a brush with stiff bristles, as it may damage the shoe material.6. Rinse Thoroughly:Wipe off any soap or detergent with a clean, damp cloth or sponge. Make sure to remove all residue.7. Dry Properly:Stuff your shoes with crumpled newspaper or paper towels to help them retain their shape and absorb moisture. Let them air dry in a well-ventilated area. Avoid direct heat sources like radiators or sunlight, as this can cause the shoes to yellow.8. Clean Soles:Clean the soles of your shoes separately. You can use an old toothbrush or a small brush to scrub away dirt and grime. A mixture of water and mild soap or a specialized sole cleaner can be effective.9. Protect and Maintain: Consider applying a stain and water repellent spray to protect your white shoes from future stains. Regularly clean your shoes to prevent dirt buildup.10. Polish (for Leather Shoes):If your white shoes are made of leather, you can use a white shoe polish to restore their shine. Make sure to follow the instructions on the polish container.Remember, prevention is key. Try to avoid wearing your white shoes in muddy or extremely dirty conditions, and clean them regularly to keep them looking their best.
4/17/2024 7:05:52 AM •
Clothing...
Answered
on Apr 17, 2024
How much would getting a wedding dress made cost?
The cost of getting a wedding dress made can vary greatly depending on factors like the design complexity, quality of materials, and the expertise of the designer. On average, it can range from a few hundred to several thousand dollars. It's important to consider your budget and discuss pricing with the designer to find the best option for you. For best designer lehengas, saree and ethnic wear you can check Mirraw Luxe online. Visit now: https://www.mirrawluxe.com/trends/wedding
3/8/2024 1:22:32 PM •
Clothing...
Answered
on Mar 08, 2024
Are you searching for Handcrafted Polki Jewellery in India?
Polki jewellery is a traditional Indian jewellery style that uses uncut diamonds in its designs. It is a popular choice for weddings and special occasions. There are many Indian jewellery designers and brands that offer handcrafted Polki jewellery, both online and in physical stores. Some popular options include Sabyasachi, Amrapali, and Tanishq.
2/25/2023 9:53:01 AM •
Clothing...
Answered
on Feb 25, 2023
What should I pay attention to when buying fashion jewelry online?
When buying fashion jewelry online, there are a few things you should pay attention to in order to ensure that you are getting a high-quality product:
- Material: Make sure to check what the jewelry is made of. Some common materials for fashion jewelry include gold, silver, and various types of metal alloys.
- Quality: Look for reviews or ratings from other customers to get an idea of the quality of the jewelry.
- Return policy: Be sure to check the return policy in case you are not satisfied with the product.
- Price: Compare prices with other retailers to make sure you are getting a good deal.
- Certification: If the jewelry is made of precious metals, look for certification from organizations such as the Gemological Institute of America (GIA) or the International Gemological Institute (IGI).
- Size: Make sure to check the size of the jewelry, as it may be difficult to return or exchange if it does not fit properly.
- Shipping: Check the shipping policies, including the estimated delivery time and any fees that may apply.
By considering these factors, you can make an informed decision when purchasing fashion jewelry online and be confident that you are getting a high-quality product. By the way if you want to buy Fashion Jewellery Online then you can visit on
Mangalmai Jewellers' website.
https://www.mangalmanijewellers.com/
I hope this answer is helpful for you. Thank You
12/17/2022 5:54:02 AM •
Clothing...
Answered
on Dec 17, 2022
Are you into imitation jewellery wholesale?
Yesssss! If you are looking for an imitation jewelry wholesaler?then your search is over here. Mangalmani Jewellers Has wide acclaimed name engaged in manufacturing, supplying, wholesaling imitation jewelry, costume jewelry & fashion jewelry.We have been instrumental in creating over 500 successful Fashion jewelry brands world-wide with over 1000 happy and regular customers and still counting. With a huge store house of over 6000 new and unique designs coupled with a very efficient in-house designing team.We are one of the best imitation jewelry manufacturers in India and also achieved the feet of becomingone of the top
imitation jewellery wholesalers in indi. We have thus become a popular fashion store providing every individual the best guaranteed products in antique, kundan and Ethnic Designs. Visit us now
11/28/2022 7:20:53 AM •
Clothing...
Answered
on Nov 28, 2022
