20 Most Recent Asrock G41M-GS Core 2 Quad/ Intel G41/ DDR2/ A&V&GbE/ mATX Motherboard Questions & Answers
2answers
I have G41M COMBO(GIGA-BYTE) mother
The onboard video chip is very weak and it can't handle the amount of data required by a game. There's only thing you can do - install a decent video card.
10/20/2010 2:27:25 PM • Asrock G41M-GS... • Answered on Oct 20, 2010
2answers
I'm using G41M-GS MB and when I turned on my pc,
Either the processor doesn't computer or the memory isn't right
3/23/2010 4:56:08 AM • Asrock G41M-GS... • Answered on Mar 23, 2010
Asrock h110 disable on board video using cards for mining only
real asrock mobo told ,just the intel chipset code H110the bios controls that in bios disable iGPU. no cpu told either as some have no igpu at all.like xeons, and some mobo can run both i3+ and zeons.see this search at asrocksee how your post has no real clues?https://www.asrock.com/support/index.asp?Model=h11029 mobo made based on only intel chipet.
5/7/2022 4:02:49 PM • Asrock Computers... • Answered on May 07, 2022
Asrock h110 disable on board video card
double posted you?of 29mobo not one told.https://www.asrock.com/support/index.asp?Model=h110the bios page,labeled, igpu (disable /enable ) is there.some mobo allow zeon here with zero igpu.but not yoursthey make h110 ,mobo just for useless now, bitcoin mining.watch the netflix movie how the blocked mining,then save moneyalso learn what ROI is?
5/7/2022 3:59:28 PM • Asrock Computers... • Answered on May 07, 2022
3answers
No display on my Asrock P4I45GV
Check Ram and fun if not properly installed
5/7/2022 2:12:39 PM • Asrock Computers... • Answered on May 07, 2022
2answers
Asrock G31M-S No Display/not Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO. If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
5/7/2022 1:13:35 PM • Asrock Computers... • Answered on May 07, 2022
MY ASROCK MOTHERBOARD OUTPUT DEVICES IS NOT WORKING
3 post all the same mobo and all 3 same reasons. and all 3 same answers. zero no I added one, coin cell is dead at 7 years, you are 2004 to 2018 late to the party. 14 year old battery is 2 times spec life. for sure.
12/29/2021 4:42:52 PM • Asrock Computers... • Answered on Dec 29, 2021
Factory reset windows 8.1 error
Wipe the hard drive and do a clean install, not repair.
9/21/2017 1:33:46 AM • Asrock Computers... • Answered on Sep 21, 2017
This is my system, -K10N780SLIX3 wifi Mobo -Gtx
swapping out parts, try with different power supply pull the ram reseat it maybe one at time. different memory slots. change one part at a time with good working part, never assume any part is good.
4/19/2017 12:36:24 AM • Asrock Computers... • Answered on Apr 19, 2017
Crack windows 7 activate
That would be ******* and we don't so that here. Sorry.
7/9/2016 6:11:53 PM • Asrock Computers... • Answered on Jul 09, 2016
Instalar windows 8
Si ustedes quieren activar Windows 8 necesita una clave de producto, te tengo este enlace para obtener algunos m?s estables: https://plus.google.com/117868268119072465334/posts/XuMyoTaUjN7.
6/8/2016 6:53:27 AM • Asrock Computers... • Answered on Jun 08, 2016
Como instalar wifi miniport adater para windows 7
Hace unos d?as, me dieron una de las ventanas 7 clave de una p?gina: http://www.instructables.com/id/C%C3%B3mo-Reparar-Error-0xC004F074-De-Microsoft-Word/. Despu?s yo uso la tecla. Clave no s?lo funciona sino que es genuino. La esperanza tambi?n puede ayudar.
6/6/2016 6:24:53 AM • Asrock Computers... • Answered on Jun 06, 2016
What Kind Of Cooling Fan Do I Need To Buy For An ASRock Q1900M Mainboard ?
Almost any muffin fan that will fit should be ok. Make sure your motherboard can run 64bit before you spend your money!
5/6/2015 10:11:44 PM • Asrock Computers... • Answered on May 06, 2015
By starting up "something" is asking permission to install mc2. What is the the meaning of this and what does this mc2 does to the functioning of my desktop?
Perhaps the install is trying to open a file with an mc2 file extension. Has this prompt at startup just started happening or has it always been happening? If it has just started did you recently download something? MC2 files are Misc Files primarily associated with Mastercook File (Sierra). There could be other programs which also use files with this file extension. It sounds like your system is trying to open a file with an mc2 file extension and does not have the proper program installed to do so. It is asking you whether you will allow it to install the file for you.
3/11/2015 12:11:00 AM • Asrock Computers... • Answered on Mar 11, 2015
Error mac address are invalid in both cmos and flash
does your mac have a battery back up battery like pc's do. the battery in the mac may not have enough power to keep the cmos information together, replace the battery and you should be okay
3/1/2015 8:25:37 PM • Asrock Computers... • Answered on Mar 01, 2015
Asrock G41M-GS Core 2 Quad/ Intel G41/ DDR2/ A&V&GbE/ mATX Motherboard Logo
Popular Tags
5 questions posted
Top Asrock Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Asrock Computers & Internet
Most Popular Question
using g41m gs mb when turned pc
  • Computers & Internet
