20 Most Recent
Biostar G41-M7 Motherboard - Socket 775, Intel G41, MicroATX, DDR2, PCIe, USB 2.0 (802700502491) Questions & Answers
Any kind of mouse & keyboard not support
It sounds like you have drivers missing, (check your device manager) or try looking on the disk that is supplied with the board else contact the board manufacturer. A USB keyboard and mouse should work, if not it could also be your OS installation. Another though is that I hope you are not trying to use your old hard drive setup on a new board, it wont work as it will be looking for the wrong components and main board. A complete re install is the answer if you have done this.or try and replace all the drivers needed for the new board.
HIGH SPEED USB HOST CONTROL
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall then
hope this helps don
I bought Motherboard Biostar G41-M7
There are problems with the video files for this board if you are using windows 7. Firstly I'd try downloading the latest drivers and see if that resolves the problem
The computer doesn't detect any
The Motherboard you have talked about supports mostly all the operating systems. If the computer is not detecting the audio driver, most probably the drivers you have installed is not compatible with the Operating System you are using right now. As you have not told what is operating system, I'm not able to find out the proper solution for you. So, I'm giving this link, where you can download all the drivers compatible for your Operating Systems (eg. XP, Vista, Se7en, etc.). For example, if you are using Vista 32-bit, then download the corresponding driver compatible for vista (i.e. Vista x86)....otherwise the driver will never work.
Here is the link for downloading your OS compatible drivers:
Download Drivers for Biostar G41-M7 Now install the driver the properly and enjoy working :)
Failure in saving BIOs
I have
Enter BIOS SETUP.
Choose Load Factory Defaults.
Save/Exit.
Or, since the motherboard is less than one week old, it has a warranty. Exercise the warranty, to get a replacement motherboard.
When I start the system is not video display
There may be problem in Monitor or VGA Card. When you Turn on PC the Monitor light is green after 10 second if It will be orange . It means your monitor is alright . but problem in you VGA Card.
When the PC turn on there is any beep.
If no beep then your RAM is alright.
Problem in VGA Card.
Biostar i945cm7b
best is noobs avoiding UEFI
and 945 is 2005 tech, not modern UEFI bios .at all
but do ask maker this.
but 945 ended there.
6/6/2022 1:34:56 PM •
Biostar...
Answered
on Jun 06, 2022
Mainboard Vestel 14MB02-03 no power
posted to computer repair help, PCwhat computer is this, not toldVestel 14MB02-03 (mobo labels useless)Vestel made this mobo under contract to an OEM PC maker,. like BIOSTAR? or who? not told really.Vestel does not sell PCs ! google shows no hits (zero). posted wrong PC model?ahhhhh coded words off mobo white painted silk screenssureI see one hit on that number alone and shows LAPTOP PC MOBOclearlyok , why post mobo models. and not real maker of PC laptop model, did you somehow lose the laptop casings.??>???????????odd odd post this is, like that. we fix PC by makers name and real models. not mobo codes. sorrythe model is on the bottom tab on laptops oldor in bios screen 1 toldnow and answer for laptops old. 1: big battery dead and worse shorted making PC dead, remove it run on AC power pack only,see it works.2: coin cell dead, sure it is that old replace it.3: any of up to 20 other modules inside shorted out.4: stuck in sleep mode dead, push power button for 10 seconds and release, runs now?5: LCD CCFL back lamps dead, use a flash light pointed to screen to see data turned on, if seen the CCFL is dead.(aka, background light tubes)
6/6/2022 12:42:55 PM •
Biostar...
Answered
on Jun 06, 2022
Audio Adapter ESS Technology ES1938/ES1941/ES1946 Solo-1(E) AudioDrive for windos 7
no PC told no OS told but it was for XPbiostar ended support. windows 7 is oct 2009 OSthe old XP driver is here.https://www.majorgeeks.com/files/details/ess_sound_card_es1938es1946_(es1969).html2006 sound cards. it is PCI not PCI-expressso is useless on all modern PC>but since you imply it fits to a PC the PC is a relic and not told the chip sets on the card are not supported by them maker of the chips so is double dead.(product line not maker)https://www.esstech.com/as you see no es1938 era support.if you google things that do not exist the prize is a nasty virus, here is a short test for w7 just for you.the waybackmachine.com shows https://www.esstech.com/going dead (for legace) 2007so dead 2 years before w7 was released.XP lasthttps://web.archive.org/web/20070202023729mp_/http://www.esstech.com/techsupp/drivers.shtmas you can see the FTP links to the drivers are dead.for ever and ever.now to w7 year, 2009 dec, 2 months from w7 releasetiming is everything , no?the endhttps://web.archive.org/web/20091213143106/https://www.esstech.com/they ended all legacy then./ that means so did biostar. with no base drivers it ends.RIP ESS legacy.
5/17/2022 7:12:49 PM •
Biostar...
Answered
on May 17, 2022
