20 Most Recent
ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z) Questions & Answers
M4A77TD (AM3) unknown devices
Hello you can download the driver here:
http://www.asus.com/Motherboards/AMD_AM3/M4A77TD_PRO/#downloadPlease select your windows system 32 or 64 bit.Open the driver folder by click on +.And download the driver by click on the global link.Unzip the file before you install it.Unknown device could be a missing chipset driver, card reader, sound card etc.Try to install the drivers one by one and the unknown device should go away.Remember to reboot when you asked to.Good luck
Getting a single beep upon
One beep means everything posted right
I would start with the video card and pull
it out of socket then reinsert it you could
have a bad card or bad cable or the
mother board cant handle vcard
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
MY NOTE BOOK DOES NOT
try to do this:
- remove the battery and charger (everything connected to the pc) then press the power button for 1 minute..
- plug back in the charger
- after few secs try to turn it on
hope this helps :D
The Ethernet port of my
Yeah, the link light on the router should be coming on.
A few simple things to try:
Try a different network cable. Try a different port on the router. Visually inspect the port on the system and router to confirm they are not physically damaged in any way.
I just purchased and attempted to install G.SKILL
Memory
-4 x DIMM, Max. 16 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Memory-
Dual Channel memory architecture
*Due to OS limitation, when installing total
memory of 4GB capacity or more, Windows® 32-bit operation system may
only recognize less than 3GB. Install a 64-bit WindowsWindows® OS when
you want to install 4GB or more memory on the motherboard.
Memory-
*Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
My pc does not boot
please check the bus speed of the RAM witch one run perfect.After you use the same bus speed RAM in another moudle.
Asus m4a77td will not recognize sata hhd's and
you will have to install drivers for the sata drive within the operating system which can be done during windows setup mode which is the only case here. you will need the drivers on a floppy or other media such as cd to do this. I you can get your hands on a modified windows with integrated drivers such as windows ultra (not made by miscrosoft but rather modified by someone to install most devices drivers). this could help or visite the website of the sata hdd to download thier drivers. good luck
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
