20 Most Recent
Sony VAIO VGN-CS320J/P Notebook Questions & Answers
Hi, my sony vaio laptop
Update first the firmware of your laptop. If the problem still occurs then contact your vendor for warranty there must be wrong on your screen's bezel and LVDS cable.
1/5/2018 3:11:59 AM •
Sony VAIO...
Answered
on Jan 05, 2018
Usb is not recognized
You will need to try the usb device on another computer and see what happends.
1/23/2014 4:20:34 AM •
Sony VAIO...
Answered
on Jan 23, 2014
I have upgrade my
SONY is like that you may have to get the update driver form SONY for that unit
12/27/2010 3:36:27 PM •
Sony VAIO...
Answered
on Dec 27, 2010
I think I have broken my headphone jack on my sony
It might be the plug on the headphone that's bad - try it on another laptop. If it's the jack that's bad, then it will need to be taken apart and that's not easy to fix - recommend having a repair shop fix it.
12/24/2010 12:34:29 AM •
Sony VAIO...
Answered
on Dec 24, 2010
Screen_flickering
On Sony VAIO laptops, I have encountered a number of them with 'inverter' back light problems. If the computer is an older one, then I would consider replacing it. If it's newer, it may be covered under warranty.
12/12/2010 4:56:09 PM •
Sony VAIO...
Answered
on Dec 12, 2010
Sony vgn-cs320j av and capture
Hi barca3250,
The AV Mode/Capture TouchSensor Buttons above the Keyboard will not work if the Touchpad Driver in the Computer is not installed correctly. Please download and install the Touchpad Driver from the below link to fix the issue.
ftp://download.sony.com/US/pc/SPDOTH-00174505-64.EXE
Please restart the Computer after the installation.
This should fix the issue.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using Fixya.
10/21/2010 11:54:37 AM •
Sony VAIO...
Answered
on Oct 21, 2010
PARA QUE ES EL TOUCH SENSOR AV CONTROLS
- Click the Start button, and then click on Computer .
- In the Computer window, under Hard Disk Drives , double-click on (C:) .
- Double-click the Windows folder.
- Double-click the DRIVERS folder.
- Double-click the .EXE folder.
- Double-click the Pointing Driver (Synaptics) folder.
- Double-click on the setup or setup.exe icon.
- Follow the Synaptics Pointing Driver Installation wizard instructions to install the driver. NOTE: When the installation setup is complete, a You must restart your computer to apply these changes window will appear. Choose the Restart Now button for proper installation .
Downloading and installing the Synaptics driver update available through the Drivers & Software link on this page will also resolve this issue.
Download the Driver here.
8/5/2010 2:51:02 PM •
Sony VAIO...
Answered
on Aug 05, 2010
Want to upgrade from vista to windows 10
The Microsoft website will give details of how to upgrade and the costs involved, though buying the new operating system on hardware and performing a drive format and a clean new load could make more sense.
A computer that previously ran Vista will probably be a few years old and therefore have a low specification so you could be disappointed with the performance when running Windows 10.
I have a very old pc originally running Windows 95 that copes well with XP without perceptible loss of functionality for modest purposes, which makes no sense at all.
On the other hand a relatively high-spec laptop I own needs a fair amount of patience running Windows 7.
You have to try these things but the results aren't assured and it is a bit like making a wager with your cash. Might be more economic to buy an up to date machine.
11/23/2015 2:17:18 AM •
Sony VGN...
Answered
on Nov 23, 2015
How do i send photo files that are on my laptop without losing the pictures
Hi Irene - There are many ways to send photos and so I am assuming you are sending them by email. If this is not correct, please provide more info. Within your email program send a new message. In the new message, click on Attach File or Insert Picture. Which ever you choose, it will open a box that will allow you to locate your photo files on your laptop. Select the ones you want and they will be added to the email. They will also remain intact on your laptop. Hope this helps. Thanks.
1/20/2015 4:48:03 PM •
Sony VGN...
Answered
on Jan 20, 2015
