20 Most Recent Samsung R620-63G Notebook Questions & Answers
User Verification of Solution Verify_YES
Not sure what combatmode is, you may want to upgrade your operating system. Windows XP is an EOL product.
2/25/2019 6:03:24 PM • Samsung R620-63G... • Answered on Feb 25, 2019
Verify_yes
I have no idea what your question is?
12/13/2013 1:30:14 PM • Samsung R620-63G... • Answered on Dec 13, 2013
0answers
R620-63g bios password
BIOS passwords can be reset or removed in two ways:1. using software 2. using hardware..I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.You can download it here:http://www.syschat.com/download120.html&act=downCmosPwd - Cmos password recovery toolshttp://majorgeeks.com/CmosPwd_d239.htmlYou will need to create a bootable Dos, or Linux or NT cd in order to run them.Good Luck!
9/4/2012 3:21:12 PM • Samsung R620-63G... • Answered on Sep 04, 2012
How can i restore my
Well, you can order Recovery Disc from Samsung which can be used to restore the laptop to factory settings.
If you wanted, you can install an operating system on your own. You need to either buy a copy of Windows or download it. If you download a copy of Windows you need to burn it to a CD or USB. Then boot the laptop up into the USB or CD and it will install Windows. It will reset the computer to new but not exactly like it was when you purchased it. Why? Well, Samsung and other companies preload a lot of junk software into the laptops with the operating system. This is how the make extra money. That is one reason why I don't really use the factory recovery disk.
Let me know if you have any questions.
Regards,
G33k
7/9/2011 3:46:32 PM • Samsung R620-63G... • Answered on Jul 09, 2011
Black screen when i start
Hello
Try to restore the system by booting into safe mode and doing a system restore from the last time the laptop worked fine. It appears that a windows update was performed that may have caused the issue.
4/16/2011 1:04:43 AM • Samsung R620-63G... • Answered on Apr 16, 2011
Computer tied to network but isnt recieving
Before doing a hardware reset, please check this for me:
Start --> Run --> Type inetcpl.cpl
Inside of here:
Top right, click 'Connections'.
Towards the bottom of the box is a button that says: 'Lan Settings', click it.
Once this box opens up, check to make sure that the box that says: 'Use a Proxy Server for your LAN' does NOT have a check mark. I repeat, make sure that the box is NOT checked. If it is, uncheck it and press okay, then okay again.
Re-check your internet.
Thanks and hope this helps! if it does, please rate!
3/29/2011 5:25:51 PM • Samsung R620-63G... • Answered on Mar 29, 2011
I have a samsung r620
Check whether is there a device that is emitting ay magnetic field (like a sub woofer or a speaker or a radio) that is interrupting the graphis card.
try connecting an external monitor and check whether the same issue is happening so that you can confirm whether the issue is related to the LCD of the laptop or with the graphics card it self and replace the LCD or the motherboard (the graphics card will be integrated onto the motherbard) accordingly.
12/31/2010 9:51:28 PM • Samsung R620-63G... • Answered on Dec 31, 2010
My model is the np355v5c-ao6uk, i got it from the auction, its passworded and l cant get into the system
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed http://wiki.ljackson.us/Control_Userpasswords2 if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. http://download.cnet.com/lazesoft-recover-my-password/3000-18501_4-10973339.html Lazesoft Recover My Password Home Edition is a very easy to use Windows password recovery freeware http://download.cnet.com/password-cracker/3000-2092_4-10226556.html password cracker free
5/28/2019 2:54:50 AM • Samsung R... • Answered on May 28, 2019
0answers
The backup folder created by Samsung Recovery Solution has changed how to fix ??
try doing a restore to when you last seen it
4/12/2015 3:23:16 PM • Samsung R... • Answered on Apr 12, 2015
How to hard reset?
Dear There is no hardware reset. however you can opt for the default setup at bios setup before booting. (pressing delete key. Thanks.
4/1/2015 11:25:58 AM • Samsung R... • Answered on Apr 01, 2015
2answers
LAPTOP WILL NOT START
check mains lead and fuse pluse battry,try starting up with out the battry just the mains.
3/30/2015 5:20:43 PM • Samsung R... • Answered on Mar 30, 2015
Samsung R519 irregular beeps on startup
check your ram it could be faulty.or over heating,check and make sure your fan is running.if its the fan get a hoover and clean it out.
3/30/2015 3:54:34 PM • Samsung R... • Answered on Mar 30, 2015
Battery cannot hold the charge
you need to change the battery
3/30/2015 3:45:36 PM • Samsung R... • Answered on Mar 30, 2015
My samsung laptop won't turn on at all. nothing
try starting it up with out the battery just the main lead.,or check the mains lead. check fuse in main lead.
3/30/2015 3:15:48 PM • Samsung R... • Answered on Mar 30, 2015
It prints a descriptive page after each document page, why?
Dear You may do un install and reinstall the application software. Thanks.
3/17/2015 5:54:54 PM • Samsung R... • Answered on Mar 17, 2015
How to hard reset a laptop r430
http://support.hp.com/us-en/document/c01684768
3/17/2015 4:50:11 AM • Samsung R... • Answered on Mar 17, 2015
Samsung R620-63G Notebook Logo
Popular Tags
15 questions posted
Popular Products
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
R Samsung
  • R Samsung
Most Popular Question
samsung r620
  • Computers & Internet
