20 Most Recent Toshiba Satellite A505-S6975 Notebook Questions & Answers
Have a toshiba satellite a505, suddenly it turned off, i tried to turn it on but it just starts to get on and it turns off again,
Bonjour, Le mieux reste d'aller chez le r?parateur pourvoir ce qui ne va pas et agir en cons?quence, mais il est possible que vous soyez oblig? de changer certaines pi?ces alors j'esp?re que ceci vous sera utile: https://www.distriphone.com/en/5584-Toshiba-Laptop-Parts
1/22/2020 8:46:00 AM • Toshiba... • Answered on Jan 22, 2020
My home page freezes
I would run a good virus or malware program, there are some very good and free ones available. Try Malwarebytes, AVG and Spybot S&D, all available free and all very good. Hope this helps.
1/21/2012 5:23:55 PM • Toshiba... • Answered on Jan 21, 2012
Satellite A505 laptop running windows
Sleep and hibernate options are part of Bios. what i mean by that is if these is an issue with Bios these features wont work. Sometimes there has been known issues with cordless mice and other devices plugged in via usb port. Also outdated video and other drivers will do same. i would recommend first of all going to manufacturers site and downloading latest Bios update for your system, once this is done run windows update and make sure pc is restarted once done. After all this go back to your manufacturers site and download all of the driver updates that are available. Hope this helps.
3/10/2011 3:18:18 AM • Toshiba... • Answered on Mar 10, 2011
My Toshiba A505-s6975 laptop is
Seems like a common issue with A505's. After a fruitless google search I basically went to speaker balance (which I had to google how to for win7!) and increased level to max for both left and rights and so far so good. Hope that helps.
2/19/2011 9:41:42 AM • Toshiba... • Answered on Feb 19, 2011
My fan has stopped working
This seems to be a common problem with laptops over a couple of years old. Dust gets trapped in the copper fins and the fan of the CPU heatsink and reduces the efficiency of the cooling, which results in regular power off's by the laptop as it gets over it's upper temperature setting. The fix is relatively easy, just remove the heatsink unit, blow it clean with compressed air, clean the old CPU heatsink paste off with isopropyl alcohol (IPA) and spray a thin film of heatsink paste on the CPU.
If this does not fix it, you need to replace the fan.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2/6/2011 6:42:28 AM • Toshiba... • Answered on Feb 06, 2011
I tried to install sun solaris 10 in my laptop
you can get help from HERE
Good Luck
12/1/2010 9:40:49 AM • Toshiba... • Answered on Dec 01, 2010
2answers
I want to fresh install my A505 - 6965 Toshiba to
if you have windows-7 which run on your laptop you can install it, I think you no need to drivers to install your win-7 automatic install the drivers when you connect your laptop to internet. remember desktop version and laptop version win7 is different.
11/1/2010 8:09:03 PM • Toshiba... • Answered on Nov 01, 2010
My Toshiba Satellite A505 laptop
Take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
9/29/2010 3:16:49 PM • Toshiba... • Answered on Sep 29, 2010
Web camera not active
Without any more information, the issue could be with driver for the web camera or the bundled software for starts web camera.
Both can be updated from the Toshiba web site...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2351132&rpn=PSAP3U&modelFilter=A505-S6975&selCategory=3&selFamily=1073768663#
Make sure you do not have another program trying to access the web camera at the same time - such as MS or Yahoo Messenger.
If this fails, go to Computer Management (Start then search for Computer Management) - go to the Device Manager and make sure you can see the web camera on the right side of the window. If you cannot find the web camera, look for a yellow ? and update the driver using the above link.
4/30/2010 11:23:12 PM • Toshiba... • Answered on Apr 30, 2010
Toshiba a505 laptop won't print on shared home network
make sure printer is shared on nerwork and install print drivers on your laptop
4/13/2010 5:42:34 AM • Toshiba... • Answered on Apr 13, 2010
Toshiba Satellite A505 i7 processor, windows 7.
you have to try needle nose plyers it sounds like card was inserted wrong once out restart pc and then it should find it, that is as long as connectors werent ruined
4/13/2010 5:34:03 AM • Toshiba... • Answered on Apr 13, 2010
3answers
My satellite a505 laptop has windows 7 on it and
Uusally, now a days you do not get a disk with a new computer. Instead, if you go into the toshiba folder under programs on the start menu they will have a utility to make recovery disks. These disks can then be used to completely redo your computer should you need to.
Hope this helps.
2/21/2010 5:05:07 AM • Toshiba... • Answered on Feb 21, 2010
Toshiba Satellite laptop speakers don't work.
It Sounds like a Hardware Fault. I would really advise you to Return / Replace / Repair the notebook as even if you try and check the connections would Void the Notebook warranty.
But, i could at least tell you, it could be as small as wiring to as big as Speaker malfunction. However, it is not a software problem.
Note - I am Assuming that you have checked the Basic Settings.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
1/13/2010 5:14:47 PM • Toshiba... • Answered on Jan 13, 2010
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
Toshiba Satellite A505-S6975 Notebook Logo
23 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
wanna webcam driver
  • Computers & Internet
