20 Most Recent
HP Pavilion g60-440US Notebook Questions & Answers
How to update bios hp pavilion g60
Go
HereChoose your operating system and then click on BIOS and there is you BIOS update. Download and then install and it will direct you from there on. Thanks, Cody
Hard drive
It means that your HDD is damage, no good. Need to get another one and reformat your computer. The way to troubleshoot any computer that won't turn on is checking the power supply fan to see if it does anything when pressing the power button. If you see that the fan try to start but stall, then there is a bad hardware install. What I do is take all the hardware out and start the troubleshooting by installing the hardware one at a time. When the computer stop responding after installing one of the hardware, then it means that this hardware is bad. You already troubleshoot the computer by installing the HDD and seeing that the computer won't start.
Plugged in and not charging
Sorry to read about your problem, I hope this helps you out.
you have defective power supply or charging circuit
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
No audio. Test ok.
Try to check the volume gauge in your laptop, or check if the driver of the audio is already installed. Check also the volume at the lower right of your desktop and change it.
Keyboard got wet several keys
Find a container large enough for the device and remove its battery. Place the device in the container and cover it with dry rice overnight. The rice will absorb the moisture. You may need to use compressed air to get any grains of rice out of keyboard and other crevices.
I install xp in my
well is you must collect all hardware info. and go to the severall hardware brands to get drivers ex: if video card is nvidea you must go
www.nvidea.com to get driver, and so on.
after 13/7/2010 the microsoft has winxp and vista "end of life", status. so no updates\support is delivered from microsoft.
I have a HP G60-440US and it displays replace Hard
The error codes which represent the # 300 or above usually indicate that the issue might be with the Hard Drive or the RAM Modules.
You may first try performing the Hardware Diagnostics and check for any issues with the Hard Drive or RAM Modules.
If the issue still persists, it would be better to get the Unit examined at the Service Center.
Hope this Helps.
My laptop shut off by itself, and wont turn back on
Sounds like a thermal shut down switch was tripped. In plain English that means it probably overheated. Was it on your bed or your lap. There is only one small vent that draws air in and one that exhausts it. If these a covered the laptop will get hot very fast shut down to prevent further damage. You should also use a can of compressed air to blow those vents out on a regular basis to prevent blockage.
Not charging
No, there is nothing wrong with your charger. Its a voltage irregularity problem. Once it happens next time, remove the charger, remove the battery, put the battery back and try again.
I use HP 530, and I experience the same problem once in while but not every time.
Good luck.
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
