20 Most Recent
Toshiba Satellite P505-S8950 Notebook Questions & Answers
Satellite P505 Model S8980 - unable to get
----- control panel - mouse - see if touch pad disabled there
----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used
----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9
----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad
----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
8/25/2014 6:11:11 PM •
Toshiba...
Answered
on Aug 25, 2014
Bios stuck wont boot
If you can use the bios, find "set bios defaults" (usually in the last tab) and select. Then save and exit. Restart
1/25/2014 7:37:45 AM •
Toshiba...
Answered
on Jan 25, 2014
OS Not Found?
Your operating system may be corrupted... have it check by a technician to make sure you don't lose the data stored in the hard disk...hope this helps
4/14/2012 11:27:32 PM •
Toshiba...
Answered
on Apr 14, 2012
Toshiba Satellite P505-S8980 Cannot get
As per my knowleger you have not installed touch pad drivers for your Toshiba Satellite P505-S8980 if you have installed it, try reinstalling it.
3/8/2011 5:58:53 AM •
Toshiba...
Answered
on Mar 08, 2011
Need to disable cmos password
After a quick read-through of the user manual for the P505-S8950, the only way to discharge the CMOS memory seems to be removal of main battery and power cord for and extended period of time in order to cause the CMOS battery to discharge.
There may be a way to open the laptop and remove the CMOS battery to speed-up this process; however, my previous experience with taking apart a Toshiba laptop led me to the realization that they are not designed to be easily disassembled -- I had a heck of a time reconnecting the display data cable (I had to use a chopstick and have a lot of luck to get it back together).
I would suggest opening each of the access doors on the bottom of the computer in order to determine whether or not you can get at the CMOS battery that way; otherwise, I think your stuck with waiting a LONG time for the CMOS battery to discharge or VERY carefully disassembling the laptop.
12/30/2010 12:11:10 AM •
Toshiba...
Answered
on Dec 30, 2010
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM •
Toshiba...
Answered
on May 22, 2023
How can a fix error code oxcoooooof
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
3/19/2020 10:52:50 AM •
Toshiba...
Answered
on Mar 19, 2020
