20 Most Recent Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Questions & Answers
Lock light stays on. Cannot use dishwasher?
Hi
Thanks for using FixYa. To turn off the lock press and hold the Heated Dry button for 10-15 seconds. If this does not help the unfortunately you’ll have to replace the control panel.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
1/22/2015 6:29:00 PM • Kenmore 24 in.... • Answered on Jan 22, 2015
2answers
Kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
2/28/2013 1:45:52 PM • Kenmore 24 in.... • Answered on Feb 28, 2013
Kenmore elite dishwasher does not stay closed
Please check this link: door lock
7/6/2012 1:25:21 PM • Kenmore 24 in.... • Answered on Jul 06, 2012
Kenmore Smartwash dishwasher leaks water
pull off the toe kick and get a flash light and see what is leaking. it might be simple to tighten a loose connection.
1/31/2012 11:45:05 PM • Kenmore 24 in.... • Answered on Jan 31, 2012
Kenmore Dishwaster 665-16352301: Just stopped
there is a replaceable fuse in the control panel by removing splitting the door panel when its open
7/10/2011 3:00:11 AM • Kenmore 24 in.... • Answered on Jul 10, 2011
We have a Kenmore Ultra
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
2/20/2011 7:44:29 PM • Kenmore 24 in.... • Answered on Feb 20, 2011
Spinner replacement
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
10/27/2010 4:12:30 AM • Kenmore 24 in.... • Answered on Oct 27, 2010
Cloudy white film on dishes after the cycle has completed.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
9/30/2010 1:43:56 PM • Kenmore 24 in.... • Answered on Sep 30, 2010
Kenmore Elite dishwasher 665-16352301 - rinse
It appears your rinse aid level switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
9/30/2010 3:32:42 AM • Kenmore 24 in.... • Answered on Sep 30, 2010
It appears your jets are clogged in this instance.
9/30/2010 3:05:00 AM • Kenmore 24 in.... • Answered on Sep 30, 2010
The dishwasher is leaking..The rubber seal looks
Here is a tip that I wrote about dishwashers and them leaking.Leaking Dishwasherheatman101
bb
9/29/2010 2:59:45 PM • Kenmore 24 in.... • Answered on Sep 29, 2010
Dishes in top rack do not get clean; spray arms
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
A bad heating element causes many problems indishwashers...
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
9/22/2010 2:43:59 AM • Kenmore 24 in.... • Answered on Sep 22, 2010
Loud buzzing noise throu8ghout cycle. Sometimes washer sticks in wash mode
It appears your timer/main controller/CCU has failed in this instance.
9/21/2010 5:12:19 PM • Kenmore 24 in.... • Answered on Sep 21, 2010
Soap stays in disperser. Water is 142 degrees,
Either:
  1. check if the bottom rack is inserted correctly. Try turning it 180 degrees and run the cycle. Make sure nothing obstructs the dispenser.
  2. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  3. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  4. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
9/11/2010 6:19:58 AM • Kenmore 24 in.... • Answered on Sep 11, 2010
I have a 7 year old Kenmore 24" (mod. 16532201)
There are several items apart from the door seal in the dishwasher that comes in contact with the wash water that circulates inside the dishwasher.
One will have to eliminate one by one - the most likely cause is the washer pump that circulates the water.
1. water inlet hose
2. water inlet solenoid
3 wash pump
4. dispensers
5. drain pump
6. heater
7. thermostat
8. float assembly
9. washer arms and dishracks
But the likely cause could be the bearings on the wash pump or the drain pump which are deteriorating.
You could have these checked.
Good Luck.
Please post a comment if you want to know anything more specific.
9/4/2010 10:46:43 PM • Kenmore 24 in.... • Answered on Sep 04, 2010
The clean light is blinking and the dishwasher
Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.Try out his and see what happens.It must reset the memory and your dishwasher must work.
7/22/2010 8:20:11 AM • Kenmore 24 in.... • Answered on Jul 22, 2010
Soap dispenser cover will not open when in wash mode
First be sure nothing is blocking the dispenser from opening like the rack broken or an attachment to the rack out of place. If this is all good then clean good around the latch for the door, make sure soap or anything else is not causing it to stick. If all this is good you will need to replace the dispenser.
The part number for the dispenser is 9744543.
To replace it you will need to turn the power off and open the door of the dishwasher, remove all the screws that are on the inner liner on top and the 2 sides. This will allow the the inner door panel to separate from the outer door panel. You should be able to see the screws on the back side of the dispenser from there, 6 total. If the coil (the piece the wires hook to) is melted then I would suggest replacing the control board in the console at the same time as the dispenser, this would be a very rare occurrence but if it is melted it could have caused damage to the control.
Let me know if this helps
4/25/2010 7:33:41 PM • Kenmore 24 in.... • Answered on Apr 25, 2010
Kenmore 24 in. 16352 / 16354 / 16359 Built-in Dishwasher Logo
53 questions posted
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
kenmore elite dishwasher not stay closed
  • Dishwashers
