20 Most Recent
Guess G85675G WristwWatch Questions & Answers
My analog Guess watch has
Your problem is caused by the fact that the watch is 12 hours out of step.
Wind your watch forward 12 hours, reset the date if you need to and you watch will then change around midnight.
(if you need to change the date more than one day, when it has past the change time, wind it back and then forward to step the date forward. You may have to experiment to see how far past the change point (in both directions).
Watch glass broken Paul Cotello ladies watch.,
<P>Thank you for contacting FIXYA.</P><P>Most watches you can take to a local watchmaker and they can actually cut MOST crystals. It really depends on the style of the watch. You may want to contact a local watchmaker first, but here is a site you can try also:</P><P><A href="http://www.crystalfit.com/">http://www.crystalfit.com/</A></P><P>You are right, Couldnt find anything about that brand on line. </P><P>Best regards.</P>
Replace a battery cover in a guess watch
Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
which take lots of time try expert watchmaker hope you get it fix.
even thought it fix some time it's lost capability to keep your watch save from water.
hope this info help
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email:
[email protected]
Web:
www.goamfix.com
Guess g10150g wrist watch
You really should take it to a jeweler who will have the proper tools to do this without damage to the band or watch, but if you feel you are able and don't mind the chance that you might scratch it.
...you will need a very small (the kind you use for your eye glasses) screw driver -flat head type, and a way to tap (a tack hammer) get a cloth to lay down (dark so you can see the small parts) and work on this surface. Look at the small holes on either side of the band and look for a ( - ) this is the end of the pin that must come out first and this is the direction you will force out the pin from the chamber. To force out the pin you must put the head of the very tiny screw driver on the OPPOSITE end and gently tap the screw driver to push the pin out, once you see a small portion of the pin, pull on it with a pair of pliers, but try not so squeeze it for fear of damage. Repeat at the next pin you wish to remove or 2 or 3 depending on how many you want out. Once you have removed all you need to, hold the links from where you have it separated together and push the pin back up inside the chamber **but make sure it is going back in as it came out---the pin will look sort of like a bobby-pin and the Rounded end goes in first** After you push it in by hand, you can use the tack hammer to tap it back down to make it flush, then use the screw driver to get is just below the surface of the band.
How do I change the battery on a Guess WO872G2 watch
Here's a Youtube for changing the battery or flip the strap inside out and use a small kitchen knife to pry off the back where there is a small lip. I used a magnifying glass to find it near the strap. https://www.youtube.com/watch?v=d9E7G-ajBn0
12/29/2018 11:43:22 PM •
Guess Watches
Answered
on Dec 29, 2018
