20 Most Recent
AMT Datasouth Aries MK238 Weapon Sight Questions & Answers
Power light turns on, Infra
Hello, bad image intensifier tube and possible ccfl with it coil. Major repair on MK238 scope. I think they make a generation 2 tube for this scope like 350,360,390, and 410. Call AT ATN. stewbison
Put in battery and light
Jeepers! I have work on these ATN MK238 before. All internal electronic are made in Russia. There are two major problem with them. Image intensifier tube goes lights out, the ccfl inver, coil and voltage multiplier are seal in dielectric jell and epoxy. can't work of them. I can work on them, but I am not. Who ever work on it will need to install a new image tube, manufacture ccfl inverter, fine a coil and manufacture voltage multiplie and get the correct cathode ingnitor voltage, hard.
Sorry, I wish you all the luck. They one more option send it ATN and before you send it call ask what the price will be, and get the guys name or record it. stewbison
Lens diagram aries 238
Hi, the objective lens on this ATN MK238. Now these lenses are Russian Optics
and they manufacture very good to excellent optics. Take the lens to a camera
shop, if they can fix it, then they will know who will. If you send it to ATN
they just throw away your lens and replace it with a new lens. If you are going
to replace the lens then up grade to 90mm to 100mm lens, OK. stewbsion
Amt aries mk238 model#500433
I have a Amt aries 208 I have changed the battery but i cant get to do any thing . and i have lost all of the manuals can you help.Ed.
Amt aries mk238 dont work turn on dont see nothing
Have the capacitor check in the circuit. They do hald a charge to turn the sytem on. If the capacitor has cracked it will not operate for you. They do crack from the build up of heat generated by the voltage running through it. Once cracked they will not hold there charge to turn on
Were is serial number on amt night vision
You may have a unit that does not have a serial number if nothing is embossed on the unit, their website indicates not all are going to have a serial number.http://www.atncorp.com/
9/4/2015 9:30:40 PM •
AMT Optics
Answered
on Sep 04, 2015
Cannot see anything
Hello, AMT is no longer here. ATN Inc owns it stuff now. It is the image intensifier tube that has gone bad, and these thing are manufactured in Russia. Auction it on eBay. Sorry, GB..stewbison
9/26/2011 2:40:09 AM •
AMT Optics
Answered
on Sep 26, 2011
When I turn it on
Yes, probably with a new image intensifier tube, or it could possibly be weak ccfl inverter with it coil. Contact the manufacture and they will give you ruff estimate on the cost for repairs. stewbison
8/10/2011 5:00:59 AM •
AMT Optics
Answered
on Aug 10, 2011
Display won't light up In
try emailing them on www.
[email protected] or phone on
800-910-2862,,,,650.989.5100...fax..650.875.0129..
atn 1341 san mated avenue,,south san francisco,,ca 94080..
now my brain hurts???
8/28/2010 1:35:50 PM •
AMT Optics
Answered
on Aug 28, 2010
How to install a pc camera
insert the driver cd wait for the command on your monitor , then enter next to finish then plug the usb cam
3/6/2010 3:10:07 PM •
AMT Optics
Answered
on Mar 06, 2010
