20 Most Recent
Safe International Stack-On Personal Fire Safe - ETL Rated Fire-Resistant, Electronic Lock, 17 Questions & Answers
Bumil safe
Hope my experience helps someone: followed instructions above, removed batteries, unscrewed 2 Phillip screws. This allowed the electrical assembly to be lifted off the door. No override key hole or anything. What I did notice though was that the negative (black) soldering connection point was completely corroded. Greenish white stuff. The red positive side was fine. Used a flat head screwdriver to scrape gunk off to expose the metal contact. Then also exposed some of the black wire (shiny metal). Placed fresh batteries back in, and pressed the freshly exposed contact and wire together. Voila, the unit beeped and came nack to life. Entered combination, managed to unlock and open the safe. Re-soldered the contact and wire together. Fixed. Just simple corrosion resulting in loss of electrical conductivity. Crude electrical system, easy fix.
1/5/2024 2:02:56 PM •
Safe...
Answered
on Jan 05, 2024
Low batteries in my safemark safe- how do i open?
e-bar is not a battery problem, it means the door lock is jammed, either use a rubber malet or your balled up fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard a you can, your will hear the rods moving and unlocking the door. Hope this helps. I know it works I do this at the hotel I work in.
10/2/2013 5:12:49 AM •
Safe...
Answered
on Oct 02, 2013
