20 Most Recent Vizio VT420M LCD TV Questions & Answers
Vizio VT420 has scrambled display, no stanby lamp or power on lamp, PS 12V meas 11.35 and Tuner works
I'd go with a power board for starters, are the other voltages ok on the power board or are they all low
3/6/2018 9:44:57 PM • Vizio VT420M LCD... • Answered on Mar 06, 2018
2answers
I have a vizio model vt420m. When I turn it on the
Hi, it seems a main board issue but for better assistance you can contact Vizio technical support using the information shown bellow: Email: [email protected] Tel: (877) 698-4946 Fax: (949) 585-9563 Hours of operation: Monday - Friday: 6 am to 9 pm Saturday - Sunday: 8 am to 4 pm Please have your VIZIO model number, serial number, and date of purchase available before you call.
12/25/2017 11:14:18 PM • Vizio VT420M LCD... • Answered on Dec 25, 2017
2answers
No picture or sound.
Hi, it seems you have a faulty mainboard, but the better and more secure option to avoid spending money unnecessary it's to contact directly to Vizio technical support: Email: [email protected] Tel: (877) 698-4946 Fax: (949) 585-9563 Hours of operation: Monday - Friday: 6 am to 9 pm Saturday - Sunday: 8 am to 4 pm Please have your VIZIO model number, serial number, and date of purchase available before you call.
12/25/2017 11:06:07 PM • Vizio VT420M LCD... • Answered on Dec 25, 2017
I have a Vizio VT420M. When I turn it on by remote, or power button, the Vizio light changes from amber to white, but I get no picture at all OR sound. Do these symptoms sound like a bad power supply,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
3/25/2017 4:20:19 PM • Vizio VT420M LCD... • Answered on Mar 25, 2017
I've owned a Vizio VT420M for just over 13 months.
The flickering is most likely due to a faulty fluorescent backlight. Once the bulb heats up the flickering usually goes away. Some bulbs are easier to replace than others so I would contact your local TV repair shop.
10/28/2015 1:48:30 AM • Vizio VT420M LCD... • Answered on Oct 28, 2015
Hi I have a vizio vt42om the logo lights up then goes off is that the inverter board or the power supply or just the fuse
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
12/2/2014 6:45:09 AM • Vizio VT420M LCD... • Answered on Dec 02, 2014
2answers
Upon powering on my xvt47sv
The main board of this Vizio is known to fail after some use.
Its number is CBPF9D1KZ4 and as you will see it is hard to find, unless you want to pay $250 or so, which doesn't make any sense, at least to me.
Another common failure in those is the T-CON board, but from the sound of it the problem you have is in the main board.
Here's what I'd do if I were you: post a local ad on Craigslist, sell it to the highest bidder and use the money towards puchasing a new TV.
Not sure it's what you want to hear, but it's what I tell some customers and thus losing business that I couldn't have had anyway because it's insanely expensive and prone to more failures anyway.
If it helps you please vote for me - it helps me in turn :-)
www.coppelltvrepair.com
5/25/2013 8:02:11 PM • Vizio VT420M LCD... • Answered on May 25, 2013
Viizio VT420M has scrambled Display, Sound, Backlight and PS outputs are all there
I would suspect the main board as well
10/8/2012 1:00:48 PM • Vizio VT420M LCD... • Answered on Oct 08, 2012
My Vizio VT420M LCD TV
Now the tv u turn on u have a flashes of a picture only few sec. and died have sound left only?Yes,than the 2 long boards call the LCD inverter boards are the causes and the problems.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter board for the replacement.
9/27/2012 1:25:32 PM • Vizio VT420M LCD... • Answered on Sep 27, 2012
Usb port doesn't recongnize .wmv .mp4, avi, (basically any video)
Check your manual and see whether these are supported.
8/20/2012 11:49:57 PM • Vizio VT420M LCD... • Answered on Aug 20, 2012
Service manual
Send your email address to me by Fixya comment, and get a copy of the service manual by return mail.
8/15/2012 12:17:08 AM • Vizio VT420M LCD... • Answered on Aug 15, 2012
There is sound, but no Image.
Usually T-Con board with those symptoms.
10/13/2011 1:14:45 AM • Vizio VT420M LCD... • Answered on Oct 13, 2011
I was watching TV and
Hi. Maybe a fuse got burned, you should take it to a service center.
8/28/2011 7:09:25 PM • Vizio VT420M LCD... • Answered on Aug 28, 2011
Was told my backlight was
The backligts lamps rarely go out, but the backlights inverter boards that drive the lamps do go out often, you may need better tech that has real experience troubleshooting LCD TV.
Power supply, main board can also cause no lights on the screen. I would get second opinion.
Please read my guide to understand how LCD TV works.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/ Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find.
6/29/2011 4:52:32 PM • Vizio VT420M LCD... • Answered on Jun 29, 2011
Vizio VT420M LCD TV Logo
44 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VT Vizio
  • VT Vizio
Most Popular Question
viizio vt420m scrambled display sound
  • Televison & Video
