20 Most Recent Yes PDV-102CRT Portable DVD Player Questions & Answers
go to your color in settings on remote and turn the brightness up a notch not to much just a notch.
Yes PDV-102CRT... | Answered on Feb 05, 2011
Usually suspect condensation problem, let it dry out and try cd first.White screen maybe contact resistance in the connector due to condensation from room humidity.
Yes PDV-102CRT... | Answered on Dec 01, 2010
This unit comes with a remote control Use the remote to change the screen option and hide the elapsed time.
Yes PDV-102CRT... | Answered on Dec 26, 2009
You aren't going to like this answer - a HDTV does not need a special antenna to receive transmissions. It should work regardless of what TV/antenna combo you have.
Yes Televison &... | Answered on Sep 09, 2018
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts./
Yes Televison &... | Answered on Aug 03, 2018
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
https://homenol.blogspot.com/
https://electrohelponline.blogspot.com/
https://remotesearch.blogspot.com/
Yes Televison &... | Answered on Apr 14, 2018
A cable converter box will not work that's why when high def cable came into effect people traded their boxes into the cable company but you can go to Walmart and look at the antenna screw into the cable they run anywhere from $25 to a hundred my ex-wife got one at dirt cheap is $75 1 for 25 bucks gave her six channels
Yes Televison &... | Answered on Oct 26, 2017
Yes PDV-102CRT Portable DVD Player Logo
Popular Tags
7 questions posted
Top Yes Televison & Video Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
ray gallant
Are you a Yes Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Yes Televison & Video
Most Popular Question
no image sound normal correct tv
  • Televison & Video
